We are planning to support Tidal Connect.
However, to support Tidal Connect, we must be provided with the Tidal Connect SDK compatible with your platform (OS).
Currently, Tidal Connect SDK has not been created for the platform (OS) we are using.
In this regard, a request was made to Tidal, and if an SDK that can be used in the environment used by Rose is provided in the future, it will be supported.
So I can’t tell you the exact date.
