HQPlayer NAA feature for RS130
Hello, recently the Eversolo T8 streamer (RS130 ‘cheaper’ competitor) was enhanced with the HQPlayer NAA feature/support.
Considering that the Eversolo T8 also runs Android…can we finally expect Rose to jump in and offer the same feature for the RS130? It has now been proven that it’s doable.
Great question, I would also like to know the answer to this question.
@Nuforce @Miracle1980
HQPlayer is a very versatile player, so it would be difficult to integrate it directly into ROSE devices. However, while it is not feasible to support all of the many features provided by HQPlayer, we are currently developing support within ROSE for several useful functions (such as upsampling).
Great to know you are developing those functions. Regarding HQP, I believe is it NAA support that we need, on the assumption that all HQP functions would be applied of the user’s separate PC.
@Nuforce
In order for ROSE to appear in the output list when sending HQ Player’s output to the network, the HQ Player NAA (Network Audio Adapator) must be installed on Rose. However, currently Rose products do not support HQ Player NAA.
The NAA installation and executable files provided by HQ Player are for general-purpose OS (Windows, Linux, MAC, etc.), so they are not compatible with ROSE.
Eversolo has developed themselve (with the help from Jussi) a NAA client for android. Also Matrix Audio has their own NAA client.
So it’s possible, if you’re willing and interested in it.
As @burki mentioned, NAA client should be the target for Rose RS130.
You might want to get in contact directly with Jussi from HQPlayer. I’m sure he can easily help you implementing the NAA client for Android.
@Miracle1980
I have forwarded your request to our software team.
They will review it once again.
We will wait for an answer with hope. The presence of the NAA protocol in almost every competitor’s product has already become a standard.
But the main thing, is better sound quality when using this protocol. I tested Matrix NT-1, Gustard S26, SoTM sMS 2000 - every time I switched to the NAA protocol I heard more information from the same composition, from the same system.
I would like to know if your plans to upsample include conversion to DSD.
@Maxi-mix
Regarding the NAA protocol, we will review and evaluate its feasibility.
@Nuforce
We are currently working on adding the DSD gapless feature. Our initial goal is to have it implemented by March, but we are experiencing some difficulties in the process. We ask for your understanding that the release may be delayed beyond the originally planned target date.
if you really add DSD upsampling (hopefully, the RS130 has enough horse power for this), please rewrite your VU meter implementation.
The current one is not working for DSD since day one.
@burki
The topic of DSD upsampling is currently under internal review and research, and we are also evaluating the overall feasibility, including the hardware performance of the RS130.
As you correctly pointed out, DSD signal processing is structurally different from PCM, and we are aware that the currently implemented VU meter logic does not function properly during DSD playback.
If DSD upsampling is added in the future, we agree that the VU meter implementation will also need to be fully reviewed and improved so that it can correctly respond to DSD signals. Your feedback has already been shared with our software team for reference.
@ROSEHAN Hello, any news regarding the HQPlayer NAA implementation for the Rose RS130?
Please keep us updated regarding the progresses, if any.
I did float the idea to use HQPlayer but I need more assurance that it’s worth all the effort?
Like Native DSD, where the original recording is made in that format, it completely out performs the such where something is just upsampled to DSD.
But I am happy to be enlighten to any audio benefits that may be had.
Try it out (you don’t) need a license for it, but a PC with a lot of horse power and ideal a DAC without internal resampling.
By the way: I’m using HQPlayer with Roon and then you’ll not get metadatas → in this case the RS130 with NAA on it is senseless.
Also I don’t like the direct control (app) for HQPlayer, but this my personal meaning.
Thanks for your reply, I did think to buy a MacMini like the M5.
@Miracle1980
We are continuously reviewing the possibility of supporting HQPlayer NAA.
However, we currently have several other high-priority tasks in progress, so this may take some time. At the moment, support for HQPlayer NAA appears to be challenging on our side, but we will review it once again and provide updates if there is any progress.
Any updates on DSD upsampling ??
You can get album art and other metadata displayed from Roon with HQPlayer sing this extension: https://github.com/piercer/RooNAA6
If you have a more capable player like the T8 or NT-1 then it works amazingly.
I doubt the RS130 will ever support NAA, its just a legacy product now.
