Pretty major issue here. When I add ripped CDs to the Rose, it names the folder and adds the files to it. Because there are so many Metadata gaps, I end up having to fix a lot of this naming. Then when I am done, I move the folder into an alphabetized sub folder by Album Artist. So it goes from the main root folder to being moved to root > B > Bangles, for example.
The device used to reindex when folders were moved. For the last several weeks, it has not, meaning that when I try to play from the Music section of the app, either by directory or by search, it won’t play any of the ripped and moved files.
I can also find no setting to manually scan and re-index the on board storage, only one to delete and start over, which should not be the only option.
Please address this issue @ROSEHAN
