Local weather zones
Could you please add Twinsburg, Ohio, USA 44087?
If that is not an available, perhaps Cleveland, Ohio.
Hello. Would appreciate you adding Baltimore, MD USA 21228. Thank you.
@Orange5814 @scorchy
I have added all the areas of Twinsburg and Baltimore
Please check.
Twinsburg seems to be working. Thank ypu very much.
Thank you very much, and Yes, there are two other cities in which I also live and use Hifi Rose:
  1. Dobrich - BULGARIA
  2. Balchik - BULGARIA
Thank you so much for your quick reaction!
Tsani Baychev
@tsanibaytchev
Balchik is not a region supported by our servers.
Dobrich is currently added. Please check.
Could you please add Brigg, UK to the list of weather locations available. If this is too small a town could you alternatively add Scunthorpe, UK
Many thanks in advance
@MartynA
I was going to add Brigg but as you said it’s too small a town so I added Scunthorpe.
Thank you very much !
Hi
Please can I request that you add Trumbull, Connecticut, USA?
If that’s not available, perhaps the nearby town of Fairfield, Connecticut, USA?
Thanks very much!
Richard
@dashoon
I added Trumbull and Fairfield as per your request.
Connecticut is not a region supported by our servers so I could not add it.
Can you please add:
City Brasov
Country Romania.
@Daemoncrx
I added city Brasov as per your request.
Great! Thank’s a lot
Hi, can you please add Levice, Slovakia? Thank you.
@vreco
I added Levice, Slovakia as per your request.
Please add Halmstad Sweden :slight_smile: Thank you !
@Gorsti
I added Halmstad, Sweden as per your request.
@Toonfan
This message appears when you enter the watch screen and need to get weather information again.
Could you add the city of Meppel in The Netherlands?
Thanks in Advance!
