Local weather zones
@Evert1966
I added Meppel, Netherlands as per your request.
Can you please add the city of Newport Beach in California, USA?
@mpowerV10
I added the city of Newport Beach in California, USA as per your request.
Thx.
Is there a chance that you can fix the date format that is displayed on the clock?
In the USA, we follow mm/dd/YYYY. I don’t see this option in the settings.
Also, some of the clocks in the Always On option don’t follow AM/PM time format, rather the 24HR time format, even though 24HR is not selected.
Finally, the wind speed should display in miles per hour for USA.
@mpowerV10
You can display the date you specify on your Rose device in mm/dd/YYYY format.
Rose device–>Settings–>Date and Time–>Date Type–>Select mm/dd/YYYY.
Some clocks in the Always On option don’t follow the AM/PM time format, but rather the 24HR time format, even though 24HR is not selected. Please check if the 24HR format remains after a factory reset on your Rose device.
Rose device–>Settings–>System settings–>Factory reset.
Finally, we do not currently support the ability to convert KM/H to miles.
I will submit this request to the software team.
I do not have the mm/dd/yyyy option. I am using RS151, latest firmware.
Also, you can see for AOD, it is a mixture of 24HR and AM/PM clocks even after full reset.
For meteo, could you add REDON in Brittanny/France ?
Can you please add Northampton United Kingdom thanx
@domrol
Redon is not a region supported by our servers.
If you let me know the name of another region, I’ll check to see if it’s possible to add it.
@Rus
I added the city of Northampton United Kingdom as per your request.
Please add Baia Mare, Romania, I have RS151. Thank you!
@adit
I have added Baia Mare, Romania to the server.
Many thanks @ROSEHAN !
Could you add Inverness, United Kingdom
RS451
Can you get regions within a city?
For example some weather apps would have neighborhoods like Lincoln Park in Chicago, IL.
Also it would be cool if you also got weather alerts and alarms. (Maybe a future upgrade? )
@rogerredhat
I have added Inverness, United Kingdomto the server.
@Smegel
Our weather data provider does support neighborhood-level locations in some regions, such as Lincoln Park in Chicago, Illinois.
However, the availability of detailed neighborhood information depends on the data provided for each country and region. In some countries, states, or cities, neighborhood-level locations may not be available.
We kindly ask for your understanding that this is determined by our weather data provider, and there are limitations to what we can support directly.
Thanks for the addition
Thank you for the update.
If possible could you add Lincoln Park, Chicago, IL?
I do realize that you are dependent on your data provider, which is why I asked.
Its really a cool feature.
Bitte kƶnnen Sie die Wetterdaten von 79331 Teningen Deutschland eintragen
Vielen dank
