Local weather zones
Thank you very much!
Could you please add Weymouth, Dorset UK.
potresti aggiungere Taranto (italia)
We will review it and add it in the next release if possible.
@Arpan61
@Nornex @Arpan61
I have added Weymouth, Dorset (UK) and Taranto (Italy).
@ROSEHAN Could you please be kind enough to add Bournemouth and Wimborne? They are both based in Dorset, UK. Thanks
@zekor
I checked the Bournemouth and Wimborne stations you requested on our server. Unfortunately, these locations are not currently supported by our server, so we are unable to add them at this time. Thank you for your understanding.
@ROSEHAN many thanks for looking into this. In this case, can you please check if Southampton, UK is supported? If yes, please add to the list within UK. Thank you.
@zekor
I have added Southampton, UK to the server.
Can you add Nixa, Ozark and Springfield, Missouri USA?
@OzarkComputerTech
I have added all four requested regions to the server.
Please check if everything is working correctly now.
Hello
Please add Waghäusel Germany Thanks
@mmaurer3
I have successfully added Waghäusel, Germany, to our server.
Please check again on your ROSE device.
