I have added Lincoln Park, Chicago, IL to the server.
Teningen, Germany is not supported by our server.
If possible, could you provide a nearby city or a larger region? We’ll be happy to check if it’s available.
Hallo
Würden sie dann bitte Freiburg in Germany ist meine nächst stadt
Can You Look also for Emmendingen Germany
This Town is Near my Hometown as Freiburg
Thanky for all
Super! thank you so much
Hello. Can you add Venlo thats in The Netherlands
Thx in advance.
Hello
I am not seeing any wind speed Icon on my rs451 display
Is this feature compatible with this screen ?
On your ROSE device, if you select a location on the clock screen, you can view the weather and wind speed for that location at the same time.
Dear Support Team,
Would it be possible to add the following location, please?
Thank you very much in advance.
Dear Support Team,
would it be possible to add the following location, please?
Schwerin 19055 Germany
Best greetings!
Could you also please add Dublin, Ohio, USA?
Even if you have wind speed, compare it with your local weather forecast and you will find that the wind speed is not the same. At least that’s how it is on my 520. It usually says 2 km/h, although it has been really stormy here for two days on the coast.
I would imagine on the data that your local city provides.
And unlike Bonte’s comment… the local wind speed matches what my other weather app has to say.
My guess is that they are both pulling data from the same source.
(Considering that in Chicago, you can also select certain neighborhoods while in other cities you can’t.)
YMMV
I have added the region you requested.
Please check and let me know if everything is working correctly.
Not all locations provide wind speed information.
Wind speed is displayed only for locations where the weather data available on our server includes wind speed information.
Hi ROSEHAN,
Würzburg has now appeared and is showing the current temperature.
Thank you!
Thank you…
(Post must be 20 chars… )
