That is a distinct possibility. It’s the “it may not really matter” approach, I suppose. But IMO if you’re going to go through the trouble of doing it, spend less and use the correct adapters rather than more on a cable that is claimed to have some capability that is not inherently possible. Not to say you shouldn’t use good RF cables; you should, but buy them from companies who do this kind of thing for a living, like Times Wire and Cable or Belden. I’m all for audiophile cable searching when it comes to things analog and even digital, but until an audio company can prove they know even the remotest thing about RF transmission (even at a lowly 10MHz!), I’ll go to a specialty house for something like that.
Good points. Can you provide a link to a 50mhz cable you think is a good value ?
They’re available from a bunch of places. Look for patch cords using either RG8X, LMR-240, or LMR-400 cable. They will all work, but have different loss characteristics (which really shouldn’t matter for 10MHz) and more importantly have different flexibility. So to some degree it depends on how tricky your routing will be. Buy from a source that can provide test information for each cable they build - dB loss, VSWR, the usual. Tested cables can be found from Fairview, L-com, Custom Cable Connection, Mouser, Graybar, Digikey… even Amazon. Buy a couple of different varieties. You may be surprised at one type being better than another. I tried LMR-400 thinking it’s the lowest loss, lowest VSWR cable so it must be the best. Turns out in my system I preferred a cable using RG8X. I’m using a nano. In a friend’s system using a Ref10 SE120, he told me the LMR-400 worked best for him.
Coming back to the topic… I am curious why would anybody need external clock input on a ethernet switch? The clock on the switch has nothing to do with a digital audio clock… They are not related in any sense…
Just try it and you will know. I first had the RS130 connected to my LHY SW10. That was a clear improvement. Now I upgraded to the LHY OCK-2s. That’s even more of an improvement.
Next, is to also put a clock cable to the SW10 and see if that will even further improve…
I am sorry, I misunderstood the topic. I was thinking that somebody wants to hook a switch to an master clock device. That would be weird. But I see that you are talking about an ethernet switch / master clock combo! Why, on the Earth, would somebody need something like that? Master clock is last century technology, if you have good DAC it can ruin the sound. With present availability of affordable femto clock technology it is always best option to have a good clock as near to the DAC chip as possible… But anyway if you want to use master clock anyway then is more useful to have it in a separate box… I do not understand people constantly moanig about how ethernet is dirty and noisy and then in all that electronic dust and noise you pack a master clock in the same box! Why?!?
Because there’s an apparent advantage?
As I said, I tried and found their to be an upgrade in the SW10 clock performance over the RS130.
You may continue doubting (or rejecting) based on your own reasoning, or just try and maybe (positively) be surprised by the perceived result. It’s all up to you.
No I can not be “surprised” with something like that, have too much expirience with digital gear to know that there is no difference. But, anyway, I do not care if somebody belives whatever he wants, spending it’s own money. I am just curious about engeering part of the device. It is very odd to put a master clock in very noisy housing. External clock is usefull only when there are many digital devices to hook at. If an external clock is really altering your sound (sometimes it can happen, but not for better), then I think is time to think about buying better DAC.
I use the clock for the RS130. The dac is a PS Audio MK2 and quite Ok from the clock perspective IMO.
In engineering, more often than not, contrary effects of desired functionality need to be overcome in a functional design. That’s the engineering challenge. Buying or not is up to the customer. To you not, apparently and that’s fine by me.
You don’t have any experience with top tier audio, you only on Wiim level streamer. Please go away.
I promise you anything , the day they can afford it, they will immediately upgrade to better dacs and streamers, the ones always complain about things they can’t have, and peddle lies to make themselves feel better.
I don’t mind, when I was broke I used to tell myself same lies while I owned Wiim streamer, lol. It’s a human nature.
After all Porsche and Ferrari still get you from A to B, is true in some sense. But no need to disparage someone’s product choices unless they are usually jealous or filled with envy.
Well there are no contrary effects, just unlogical connections. In digital chain you can have only one master clock. In your case it is a external clock. But here you have two problems. First is - how to transport the clock from RS130 to PS Audio (which is very fine DAC, so we have a problem elsewhere). Yu probably go with AES or I2S, but there you have an intristic jitter in the cable which is greater than intristic jitter in the DAC.
But, no worry, your DAC has a protection measure against that - a jitter suppressor whis renders any incoming clock irrelevant. So, simply said, you can have the most accurate clock on the world hookes to RS130, your PS audio DAC doe not care for that at all because it will sync everything ot its own clock. Which is, needles to say, anyway of much better quality than your external clock. So, why you provided your system with an inferior clock is the question on which only you know the answer. But, as I said - anyway there is no influence of your master clock on your DAC. Lucky you. So, if you want to have benefits of an external clock - then buy yourself a DAC with a capability to connect external 10 Mhz clock. Only in that configuration your external clock has any sense.
You definitely do need a real DAC.
Articles about switches:
Alpha Audio never explain their methods and findings and always have unsupported claims which they want to look serious and “scientific”. This is pure snake oil marketing. When somebody wants from you to pay them in order to get explanation and methods used - it must be a scam.
The most powerful audio network switch ever: Melco Audio S1 Switch :
https://tw-my--hiend-com.translate.goog/?_x_tr_sl=zh-TW&_x_tr_tl=en&_x_tr_hl=zh-TW&_x_tr_pto=wapp
There is no such a thing as “audiophile network switch” except in marketing. There is no theoretical chance for a switch to influence the sound. Every ordinary network switch has galvanicaly isolated and balanced connection between two points. And if you want to be bulletproof sure that no EM noise is transfered between the switch and streamer - you can isolate them optically for less than 100$. There is also a lot of discussion between IT illiterate people about network switch clocks - they too can’t have even a theoretical influence on the digital audio clocks or sound going out from a streamer.
I can see that this Melco has a linear power supply. This is the worst thing you can do to your network switch.
Hey, linear power supplies offer great advantages to manufacturers – they are significantly cheaper and easier to make than proper switching ones, and can be sold to clueless audiophools at incredible margins.
To the end-user, of course, yeah, there’s no benefit at all.
This is just design. No practical purpose. There is no audio in Ethernet, just data. But I really wonder why are seven leads in the cable. If there were eight - it will defeat main purpose - CAT cable must have twisted pairs. Btw, which CAT standard is this, majbe CAT10?
Ridiculous
