I have just purchased an SW10-Pro for the exact same purpose - now waiting for it to arrive…
I am sure you will be happy with it. You can make some improvements to the way the SW10 impacts sound by making some changes to the internal SFPs, and your choice of external SFPs.
How much does it cost?
How much does what cost?
The switch you mentioned.
Thank you for the link.
Hi Bicycle, what cable do you use to connect the Esoteric to the 130 and 160? Thanks.
I was using a cybershaft … and I also bought a gustard. LHY and aliexpress have good ones too. Id buy pure silver.
I have the matrix switch, I would buy the LHY on ali express and maybe the FMC too
I did same thing w Matrix, it was gorgeous sound. My rs130 died and I bought antipodes. But I have 3 systems and still using rs151 and rs451
