No sound when playing MQA files
I am not getting any sound when playing MQA files through Roon on my RS130. RS130 is connected to A Classe Delta pre by usb.
When I play a flac file everything is fine.
Any idea on the correct settings in Roon or The RS130 to get this fixed?
@KYSmitty
Please set the RS130 output settings as follows.
  1. Even if you change to MQA Settings → Authenticator (or Decoder), you still can’t play MQA sound sources?
  2. Even if you turn off the PCM Resampling frequency, does the MQA sound source not play the same way?
I have tried Authenticator and decoder. Neither work.
Here are the other settings currently.
@KYSmitty
When I check your settings, it is normal that MQA audio sources should play normally.
  1. If you play MQA sound source on RS130 without playing MQA sound source through Roon, does the sound not sound the same?
  2. Doesn’t the sound come out the same when connected with a different cable (optical or coaxial cable)?
  3. If you have another DAC, check if the sound is the same even when connected to another DAC.
