[OTA] SW Ver 4.15.12 Software Release ( RS130/RS520/RS150/RS250/RS201 )
After update to 4.15. Log-in to Qobuz on my RS520 does not work !!
Can no longer log in to Qobuz account on RS250 - tried and reinstalled many times - very frustrating
Unsure what this means - can you help/explain a little please?
O.k., thanks. Now it works wonderful… TIDAL HiRes, Qobuz…Perfect.
Maybe I was lucky but I didn’t experience any problems today downloading either Rose Tube, Tidal or Qobuz on my RS520.
After updating to latest software version go to Rose Store and install Tidal & Qobuz via the screen on your Rose product.
Once that is done go to your ( updated today ) Rose Connect Premium App and login to Tidal and Qobuz using your chosen user name and password for each app.
You should then be good to go.
I would like to offer my sincere and heartfelt congratulation to the HiFi Rose software development team.
The current update is a major positive step in the evolution of the Rose software platform.
I particularly appreciate how the Rose Store has been reorganized. It was an excellent job.
As a very small suggestion when applications are updating in the Rose Store the pop up message should read “The Application is being installed”. I know, why do we use the past tense for a current action. That’s just how it is.
Also, the inclusion of a beta test version is wonderful.
Thanks - reinstalled app and all functional now.
Hello @Okrim , @NickH , @Schwarz @ajit @Drummer154 @yugan
About Qobuz login issue
In this case, the issue is related to the Qobuz login page within the device, and necessary adjustments are required by Qobuz. We have already sent a request for confirmation and modification to Qobuz. (We will inform you as soon as this change is implemented).
For the time being, you can use RC Premium for normal logins and other functions. We kindly request that you use RC Premium for Qobuz login until further notice.
Hi, thanks but that doesn’t work.
If I try to access Qobuz on my RS150b via the app the RS150b just returns a Qobuz log in error.
Can you please release the previous version of software for download so that I can revert to the (working) previous software.
I first read here in the forum, I haven’t done the update yet.
Are IOS or Android covered or both systems?
Should I wait before installing the update?
The previous version is stable.
Did you also upgrade the app to the latest version?
Thanks for your response and help. I re-installed the app on my phone and everything is now working perfectly - thanks again.
@Bitspeed
The schedule was too tight to add the files you sent to this update. In addition to adding the files sent, there were too many issues that needed to be resolved first.
In the next update, Dutch and French will be modified and updated based on the files you sent.
Hello. besides the new software, the vu meters freeze when you change radio channels or music tracks. the freeze is 1-2 sec. I have done a factory reset, it doesn’t help. With the previous software, you could also change the sensitivity of the vu meter, you can’t anymore. The model is rs- 520.
update on iPhone iOS + RS150b → everything works perfectly. A big thank you to the software team. All that’s missing is Lossless Apple Music and it will be perfect :+1::+1::+1:
And the synchronization issue? (see above)
The VU meters don’t work like they used to. They seem to be fixed on the highest volume before returning to lower values, so now it’s like they’re continuously on super high volumes.
After Update to 4.15.12 the RoseTube Streams stopps in middle of the Stream and must be started again. Before update there was no Problem. I have an RS201(E). What can be the Problem ? Can anybody help ? The Network Streams also stopps after 2 or 3 Songs from an Album.
Nice update. Just one little glitch. Tidal keeps login out. Everytime when I open the app I have login Tidal again (iOS) on both my iPhone as my iPad Pro. The app is the latest version on both devices.
I had that same problem yesterday morning with Tidal using the latest version of the Rose app on my iPad.
Since I logged out and in with Tidal on the Rose device the problem didn’t occur again. Maybe this will work for you?
