Hello. Can you tell me please if there is a limitation in the database of tracks around 300k with USB drives?
There is no limit to the number of songs when scanning songs stored on a USB external hard drive on a Rose device.
However, USB external hard drives larger than 10TB may not be recognized by the Rose device.
Are you having trouble scanning over 300,000 tracks on your Rose device?
I have two drivers 24tb each connected and the device discovers perfectly the two hard drives. The one has 250k tracks and the other 200k. The device scans and finds all the 250k tracks and from the other drive stops always in the same number of tracks around 50k. That makes 300k and no more can be scanned.
I was not sure what I thought was correct, so I relayed the information to the software team. They said that currently Rose devices only support up to 300,000 tracks.
As i thought there was a limitation. Is there a plan for a future update to change the limitation??? And also if the gapless playback was fixed for the DSD files???
When using the Gapless function, it is not that DSD music cannot be played, but it is currently blocked by our software. When using the Gapless function, DSD sound sources can be played, but noise occurs when playing some DSD sound sources. We will identify and fix the issue as soon as possible.
