Are there any other improvements in the beta software?
The remote pairing has been vastly improved. The beta software feels as if it has had an overall stability increase. It seems much more stable than the current version. File transfer seems easier and quicker. I have been critical of Rose but they appear to have done a very good job here so complements are due.
No DLNA improvements. I’m looking for others and will let you know.
How did you get this beta firmware if I may ask?
Or is it just the app software?
On the device, where you can check your firmware version, there’s a button to join beta…
I’d like to second the comment regarding the BT. I have found that it is linking better with my RS250, responding very well when you use the BT controller, no skipping or scrolling none stop. Press a button and it responds. I am not using a Beta version as far as I am aware, so well done Rose we are starting to see some positivity. Hopefully this will continue and not take a backward step with future SW updates. Let’s hope this progress continues again through other areas of concern that your users are raising on this forum.
Found it
Won’t do it, because it gives a warning a factory reset will be done
Just wait for the official version
While that warning is ominous, that is not what is happening to me. My settings have been retained.
I’ll wait for official version and some positive comments, I hope.
Probably a good decision.
Thanks for the reporting on the beta.
Can you go back to the official release after trying the beta?
Absolutely. Yes, you can go back. I’ve done it several times.
Maybe it’s not available in my region. When I click update to the early access version it says the current version is the latest. But I’m running the official version.
thank you for saying this on behalf of all of us who’s english is not their first language.
A frustrating Rose lisener
frank Vantvelt
Hello. I’ve noticed on my RS130 there is no true Gapless playback on DSD files when i hear a live album.
Gapless playback can be activated in the audio settings.
Rose device–>Settings–>Audio settings–>Gapless
Unless something has changed, this still does not work for DSF files.
Does Not work with dsf, right now
Not quit shure, but I believe it has worked in former releases
I know the setting and is on and with DSF files NO GAPLESS playback.
You have to improve so much despite that is an exellent sounding streamer. Your db scan engine with usb drives when adding new tracks and you have to rescan takes forever. You need a better approach to this one. Even the search engine on adroid app when searching an artist it doesn’t always shows the albums of the artist only the top tracks. You have to search for the albums to find one. And also as i mentioned the gapless playback with DSF files NOT working as it should. It has a small gap between tracks even if the setting is set to on. If you need more suggestions let me know to improve this excellent excellent sounding streamer.
