After several hours, access to the account was restored with all playlists.
There was an issue with the Rose servers until a few hours ago.
The issue has now been resolved.
Iβm still getting /storage/Rosedisk Not Connected on my android connected to 150B. Everything shows on the actual unit, just not on the app. Also Qoboz just folds shut after entering log in details. Itβs been like this for a month now, simply not good enough.
Please uninstall and reinstall your RoseConnect Premium app.
Then, take a screenshot of the screen where the app says /storage/Rosedisk Not Connected and send it to me.
Hi
I have uninstalled then reinstalled RoseConnect Premium.
Same problem. I also earlier closed then reopened SMB and ther other file settings so they are open.
Ihope you can help.
Andy.
I saw the screen you sent me.
The DB side is currently not compatible with the PC RoseConnect app.
We are currently developing new Connect apps for Mac and Windows.
There are limitations in continuing to support current functions with the existing Connect app for Mac and Windows, so a new one is being developed.
We plan to start testing internally soon, and we will prepare for you to try out the new Connect app for Mac and Windows by the end of December this year at the earliest, or early next year at the latest.
Even though it may be inconvenient, please use your phone or tablet for the time being.
Thanks for the information, I hope that the update works.
I have another question for you. I am thinking of upgrading to a RS130 streamer and RD160 DAC and would want to connect them via the SFP USB ports on both.
Can I do this with just a direct single cable, or do you still need an interface like the RSA 720 hub ?
I look forward to your reply.
Thank You
Andy Phillips
I have the RS130 and RD160, they are connected directly by an Amphenol SF-SFPP2EPASS-002 DAC cable, the sound is incredibly good, very analog, the bass is sumptuous and the mids and treble very soft. It takes about ten days to burn the cable, after that it is just bliss.
Thank you for that reply, some very useful information there. All the best.
I just bought a brand new rs201. It keeps ask me update system but when I click system update, it keeps shows err connect timeout flash on my screen and I try to reboot my router and reboot my rs201 unit. It is still the same.
Does anyone knows what to do?
I need help please
