Bonjour ,
Pouvez-vous svp me réexpliquer la façon de piloter mon RS 250 via mon IPD ( je n’arrive plus à me servir de mon IPad comme télécommande)
En vous remerciant par avance .
Jacques Dubuc
To control your RS250 with your iPad, please make sure that the RoseConnect app is installed and updated to the latest version from the App Store. Your iPad and the RS250 must be connected to the same local network (Wi-Fi).
- Launch the RoseConnect app on your iPad.
- The app should automatically detect your RS250 on the network.
- Select the RS250 from the device list, and you will be able to use your iPad as a remote control.
If the RS250 does not appear in the app, please check the following:
- Confirm that both the RS250 and your iPad are on the same Wi-Fi network.
- Restart the RS250 and your router, then try again.
- Reinstall the RoseConnect app if the issue persists.
Should the problem continue, please let us know your iPad model, iOS version, and the RoseConnect app version, so that we can assist you further.
En vous remerciant, vous êtes toujours efficace dans vos réponse …et c’est très confortable.
Pour info mon problème est résolu .
Dernière question quelle est la toute dernière version logiciel du RS 250 ?
Cordialement
Miles
Bonjour ,
Après vérification mon RS250 affiche la version 5.8 ?
Comment installer la version 5.9 ?
En vous remerciant.
Miles
Your RS250 is currently showing version 5.8 (Early Access). If you would like to upgrade to version 5.9 (Official), please follow the steps below:
RS250 → Settings → System Info → Use the Official update Version → RollBack
Bonsoir ,
À nouveau je n’arrive plus à piloter mon RS 250 avec mon IPad ….pire encore lorsque je télécharge les App Rose Connect il se passe rien impossible de retrouver ma page Qobuz .?
Jacques Dubuc
Here are a few things to check:
If your Rose device is using version 5.9 (Official), your RoseConnect app should be the app listed below.
If the Qobuz app is not visible on the RS250 and RoseConnect app, try the following:
RS250–>RoseStore–>Select the app that is not installed and install it.
Bonjour ,
Je viens de mettre à jour mon RS250 ( version 5.9 )
J’ai une fenêtre qui me demande : ( définir le mot de passe PIN ) ?
Pouvez-vous m’aider SVP
Très cordialement.
Jacques Dubuc ( Miles )
Bonjour ,
Ok pour moi code PIN …par contre je n’arrive pas à me connecter via Qobuz …quel est mon mot de passe ?
Miles
Bonjour ,
Je suis toujours bloquer via mon IPad on me demande ( pseudo vérification en double ) ?,
Miles
Bonjour ,
Je suis toujours bloquer impossible de me connecter via Qobuz suite nouvelle version 5.9
Miles
Re bonjour ,
En fait depuis ma mise à jour ce matin , Qobuz est uniquement utilisable sur mon IPad via RoseHifi.
Par contre sur mon RS 250 impossible de me connecter sur Qobuz …alors que l’ancienne version 5.8 fonctionnait très bien 🥲🥲🥲🥲🥲🥲
Cordialement.
Miles
I was having problems with Qobuz Connect this evening and decided to delete and reinstall on my RS130 and my iPad. was able to easily reinstall the Connect app on my IPad but I cannot log in to Qobuz on the 130.
I am getting same spinning circle as Milles. Will try again tomorrow.
Log in from the app, that should work. Great Rose software strikes again!
Bonjour ,
Que voulez-vous dire exactement ? Me connecter à quelle application ?.
Effectivement mon Qobuz fonctionne via mon IPad …sauf la télécommande, par contre mon soucis est de faire fonctionner Qobuz sur mon RS250 ( je me répète mais on me demande de rentrer mon mail et mot de passe et là j’ai une roue couleur sable qui tourne en plein milieu ) et il se passe rien !!!
Miles
Eurêka …ça marche à nouveau .
J’ai supprimé mes app Rose Hi-fi pour les réinstaller à nouveau et ça fonctionne comme au début .
Je pilote donc Qobuz via mon IPad en direct sur mon RS250 .
Miles
Connect the Rose HiFi app to your Rose, and in the app navigate to Qobuz and perform login there. It will cause the device to log in to Qobuz, as if you did it from your 250, except that it actually works.
This worked for me as well Boris. Thank you.
I am getting down to the core components of the RS130 that are working for me:
Streaming Qobuz using the Rose app, but not Qobuz Connect;
Playing my music library stored on SSD, both internal and external, as well as my NAS, using the Rose app.
The list of things I thought I could do but can’t, and things that have frustrated me is quite a bit longer.
Merci pour l’ensemble de ces échanges toujours aussi sympa et réactifs .
