Dear ROSE customers,
ROSE 4.0 is coming!
To become a complete network player, ROSE evolves again. Leaving behind ROSE 3.0, which we’ve been using for about 18 months, the ROSE 4.0 update is due at the end of November. We’ll give you a brief introduction to what updates will be available.
- Integrated music management
If you are a music lover, you will be using a variety of streaming and soundtracks. For you, we plan to put a variety of streaming and soundtracks in one queue and one playlist.
(Music, Rosetube, Tidal, Qobuz, Bugs)
- Search
Search across all streaming sources in use. Even if you enter a single search term, you can see numerous search results and add the music you want to your playlist.
(Only services in use are displayed - if you are not using Tidal, search results for tidal are not displayed)
- Queue
You can easily edit your playlist. Restarting the device does not erase it. Recommends and automatically plays content related to the content being played.
- More info.
More detailed information is provided on the playback screen. (Codec, bit, sampling rate, related content)
We plan to support lyrics by streaming, one by one. (Currently only Bugs are supported - Korea only)
- Digital output volume control with dedicated software
You can control the volume in Rose even when using an external USB DAC that does not support UAC 2.0 volume control.
(For USB, Optical, Coaxial, AES, I2S, HDMI)
(Native DSD or DOP not supported)
- Apply Shazam to the radio
Apple’s Shazam is applied to Rose radio. If you’re listening to the radio and find a good song, you can use Apple’s Shazam to search for it. If music information is available, you can search in Rose search tool immediately.
In addition to this, there are many more updates. Also, many existing issues will be fixed.
We sincerely apologize for the delay in fixing the issue as it took more time than planned.
This update does not end there. We will continue to fix issues and provide more convenience to ROSE customers based on the new ROSE 4.0.
Thank you for waiting.
