Problem LOGIN roseConnect
Hello. I also have a problem logging in to rose connect.
I have set a password and cannot log in.
login maniekf
Hello, you need to verify your email after registering as a member.
Please log in to the email address you entered when registering as a member and verify.
Same problem here. Can’t log in.
Can you send the verification mail again ?
kwn@stofanet.dk
Thank You
Hello @KeldWN ,
Would you check your email again?
Thank you,
Solved - Thank You ! :smiling_face_with_three_hearts:
Hello @aswiss ,
If you signed in but received no email from ROSE, please let me know your ID(email) for ROSE.
Idem impossible to connect me?
Hello @aswiss ,
Please check your email.
Hello @Herve ,
Do you have any problem with RoseConnect account?
If so, please let me know your ID(email) for RoseConnect.
Hello Roselia,
yes I cannot connect.
I’ve change in my account my email for hope it’s ok, but not.
My old email was eaucalme@wanadoo.fr, my new is vv.1953@yahoo.fr
Thanks for your help :slightly_smiling_face:
Roselia, I got to connect, I was doing my Nickname check wrong.
Thank you very much !
It’s ok, you can read my second reply, thank you very much ! :slightly_smiling_face:
I also cannot login into my RS250 after registrering. No mail received…
jvdminnen@zeelandnet.nl
Thanks in advance!
Hello @SvdM ,
Thank you,
Working! Thanks for your support :slight_smile:
I also cannot login via rose connect. I received the email and verified the account.
Hello @Esgehtso ,
  1. On which display are you stuck?
  2. What error message do you see?
  3. What’s your email address when you login to ROSE Connect Premium?
  1. The login works neither on the device or with Rose Connect under Win 10 and MacOS Big Sur.
  2. Under user account the error message is: “User information is incorrect”, unter Rose Connect “You can’t login”
  3. The email address is the same as for the forum.
    Many regards,
    Frank
Sorry, I can’t check your email address. Please message me your email address.
My email address is: kontakt@frankwinter.net
Best regards
