@Esgehtso , please check your email.
Bonjour,
Comment faire SVP pour ce connecter via Rose Hifi ??
Passeword.
Merci
Re-bonjour,
Souhaite également connaßtre la manip pour supprimer des albums aprÚs avoir ripper un CD ( classification et album ) sur Rose Hifi.
Merci
Do you mean that you hope to delete the ripped files?
Bonjour Roseloa ,
Je mâexplique :
Je commence depuis hier Ă ripper ma collection CD sur carte SSD du RS 250 âŠje souhaite supprimer certains CD qui se trouvent donc sur mon lecteur RS et Ă©galement sur mon IPad via App Rose Hifi ???
En vous remerciant par avance.
Milles
Suppression de CD rippĂ©sâŠ.
Milles
Hello, Iâm not sure if I understand correctly.
First of all, it is impossible to delete files through the Rose App.
Bonjour ,
Câest ok pour moi , jâai trouvĂ© la suppression des albums RippĂ©s via directement le lecteur RS 250 .
Merci.
Can you please contact me via email. I canât connect through the Rose app. Not getting the confirmation back from your server for signup confirmation
ThanksâŠJoe
Canât login in RoseConnect anymore
I have setup my data and got the registration mail and everything worked in the past, but now the login in the app or device didnât work anymore. Login in the Web page work.
Can you please check my E-Mail in_04@web.de?
I tried password reset on the Web page, but this also didnât work.
Your System doesnât recognize my email, so I cannot log in or attempt to set up a password. Iâm unable to use the Rose features that require a login as I canât get past this first screen.
You couldnât receive certification email?
Witam Rose ,
nie mogÄ siÄ poĆÄ
czyÄ.
kamilgrzech@wp.pl
No, I didnât receive your email certification. I need to do this first, so I can log in.
