Problem LOGIN roseConnect
Ok thanks, when I get home I’ll try…have a nice day! Fabio
Problem solved, everything ok! Thank you so much! Fabio
Hi there having problems Rose login in i had the same id always same password its says no member found .Do i need to sign rose tube too and rose radio
@loungedesignstudio
I have responded to your email.
Please check your email.
can you send me my password because I can’t reset the password via the rose app, I have to enter it manually on the rose 250a please send me the number password
@fry911
I checked the email you sent me.
