Hello. I’ve been using RS150B with Qobuz since 2022 without any problems, but after the last software update in December 2024 (Vers. 5.7.07) a problem has appeared: playing a track, it suddenly cuts off and skips to the next track; If at that moment I play the same track that was cut again, it plays in its entirety.
This happens randomly with two or three tracks each day, all the other tracks are played in full. This problem occurs whether I use RoseConnect or not. When I use the Qobuz application itself on a Windows PC in the same network (playing through the PC, without RS150B), this problem never appears. So it seems something related to the RS150B itself, or to the playback software (buffer management?, internet errors management?).
There is another thread about the same issue: “Skips while playing by its own”. It happens to me exactly the same you have described and also with the RS 150B. I am not quite sure, however, that it is due to the last software update since, in my case, it happened for the first time, after almost two years of perfect working, at the end of past November.
Thanks for letting me know. I was surprised that no one else had this problem. I was really looking for, but I shouldn’t have done it right. I’m going to put my comments in the other thread, and this can be closed.
I have exactly the same issue playing tracks through Qobuz on my RS130. The problem has only started over the last 2 weeks.
Hello, I also had issues with Qobuz streaming (dropouts, tracks skipping) on my RS130 and was able to fix them by switching to Google DNS on my router. Since then, everything has been running smoothly. Try the following DNS servers:
Google DNS (worked best for me) - Primary: 8.8.8.8 / Secondary: 8.8.4.4
Alternatives:
Cloudflare DNS - Primary: 1.1.1.1 / Secondary: 1.0.0.1
Quad9 DNS (more security, but may filter content) - Primary: 9.9.9.9 / Secondary: 149.112.112.112
You can change the DNS settings in your router. After that, restart the router and test.
If it helps, feel free to give feedback.
Best regards,
Philipp
I’ve been using it for a long time and I can’t confirm any problems with dropouts.
But I also “ONLY” use RS520.
I have connected wi-fi the RS150B and, after several hours of perfect working, it has ended to skip a track in the same way as with the ethernet connection. Thus it seems that either the issue is with the router or with the Rose. The problem is that the first is from Orange which does not allow to change the DNS. It must be done in each device and I don’t see how to do it in the RS150B.
It may be a problem with the router, but then:
1.- Several users have this problem → different routers
2.- In my case, the problem only appears when using Qobuz on RS150B, on another device it never appeared during all this time.
3.- In the other thread, a user commented that before the playback stoped and continue in the same place when the connection was recovered. That happened to me too. But now that behavior no longer occurs, instead it skips tracks.
4.- For all this, I still think that even if it is a problem with the different routers, it is something that the ROSE devices no longer manage correctly, at least they should return to the previous behavior.
5.- I’m not a network engineer, I just like listening to music. Why isn’t HIFI Rose responding to this thread? Can’t they clearly tell whether or not it is a problem with their devices?
I also think that it is due to the Rose because my router works perfectly with the TV and the computer. Before , when there were some connection problems with Qobuz at the RS150B, the spinning wheel appeared and if the system skipped to the next track after a while then a message appeared commenting that it was not possible to play the current track. Now the wheel never appears, the skip is immediate and there is no message at all.
Anyway, it would be interesting that someone having this issue and able to change the DNS to the Google one would try to do it and comment the results.
Hi there - I can report the same issue, all over sudden a track is cut in the middle and then it plays the next track with Qobuz and my RS 130. I was wondering why this happens once or twice every evening an yes I didnt had that before. Its about 4 weeks that this happens from, tiem to time. Regards Oliver
I had the same or similar issue. Tried a number of “fixes”, but finally directly contacted Rose Support and they advised to do a factory reset. Although a bit of a pain to have to set up the device again afterwards, this cured the problem and it hasn’t come back since.
I have resetted my RS150B no less than five times on different days since past November and the issue remains.
This issue affects to at least seven users (four in this thread and three in “Skips while playing by its own”) and there is no new that any of us has fixed it. I think that Rose should try to solve it.
We are checking if the issue occurs by logging into various Qobuz accounts on various Rose devices.
We will continue to play Qobuz audio and check again.
Are you having the same problem even if you follow all the instructions below on your Rose device?
Our recommendations:
Check network stability – While this may not be the root cause, a quick test with a wired Ethernet connection (if you are using Wi-Fi) can help rule out potential connection drops.
Re-login to Qobuz – Sign out and sign back into your Qobuz account in RoseConnect Premium (Settings → Streaming).
Clear and refresh cache – Under RS150B settings, clear Qobuz cache and restart the device.
Firmware Patch – Our development team is already reviewing this behavior, especially regarding buffering and track transition management. We expect a maintenance update soon to address this issue.
Many thanks for your reply.
My answers to your questions, in the order you asked them, are:
I have a stable internet connection via wired Ethernet to my RS520.
I have deleted Qobuz and logged in again on numerous occasions. It didn’t help
There is no facility to clear and delete cache on my RS 520 ( please correct me if I am wrong ).
I welcome the news that a firmware patch will be issued soon.
To be clear:
The problem of tracks randomly skipping and moving to another track still persists. It happens when streaming either via Rose Connect Premium or via Qobuz Connect.
I also have two Sonos speakers. There is no problem with tracks skipping when streaming Qobuz via the Sonos App through WiFi.
Qobuz Connect is not supported by Sonos so I cannot comment on that. -
Will the firmware patch also correct the stuttering / gapless playback issues when streaming via Qobuz Connect ( please note that this problem is confined only to Qobuz Connect. It does not happen when streaming via Rose Premium Connect ) ?
If you are experiencing the error message ‘could not connect to media route’ when playing Qobuz, please check if the same symptom occurs even after setting it as follows.
Rose device–> Settings → Date and Time → Daylight saving time → Off
Finally, reboot your Rose device
We have the updated file that fixes the issue related to Qobuz Connect.
It is not yet released.
If you want the updated file that fixes the issue related to Qobuz Connect, please let me know your Rose device model and software version by email below.
Then I will send you the updated file and how to update.
Rose device model
Rose device–>Settings–>System info–>Model -
Rose device model
Rose device–>Settings–>System info–>System version info
Thank you for your reply.
I have no error message when connecting via Qobuz Connect to my RS520. The connection works fine.
The problem which I and many other Rose customers have with Qobuz Connect is the gapless playback / stuttering at the start of each track. Until this is solved then listening to live recordings or opera, for example, is a non - starter.
I have already downloaded the file which “ fixes the issue related to Qobuz Connect “. I was unable to open it and I have already sent you photos from my RS520 screen showing the error message “OTA update failed. Try again”. You sent me a second file which was not recognised at all by the RS520.
Also, there is more than one Qobuz Connect issue to fix. Please confirm which issue the file to which you refer is fixing - the daylight savings time or the gapless playback stuttering problem ?
My guess is that it is the daylight savings problem. If that is the case, then when will we see a solution to the gapless playback issue ? -
Please also note the Qobuz issue which is not Qobuz Connect related - the random skipping of tracks whether played via Rose Connect app or Qobuz Connect. When will this be fixed ?
I have asked these questions on other threads but still await answers.
I’ve double-checked the email you sent me from the beginning.
I sent you the RS150 update file, not the RS520.
I sent you the RS520 update file.
Please let me know the progress after the update.
