Qobuz Connect support
Thank you Rose_love. I think what you are referring to is that there were gaps, or more precisely, deletions of the first notes of a song when transitioning to consecutive tracks on an album when using Qobuz Connect. I tested it this evening and that problem has indeed been fixed. Thank you, truly.
There still is a delay in picking up the first two or 3 seconds of the first song in an album. This is not 100% of the time but it does happen frequently. I will keep playing with it and get back to you if I can determine the cause, including possible user error.
I am not a playlist guy, I usually listen to albums.
@Eleven
Thank you for your confirmation. Please provide the model name you are using, Rose ID, and firmware version (check in Settings > System Information). If you are using a DAC, please provide the DAC information so we can check in the same environment. Also, if the problem is reproduced, please send a video of the problem to the email below. It will be of great help in analyzing the cause. shim1691@citech.kr
