Thx, I can reproduce it exactly like that.
As I reported earlier on this thread, I installed the official version yesterday onto my RS520.(5.9.02).
The â glitch when playing the next songâ appeared immediately. It is random and appears in the form of a quick â stutterâ before the track is played.
Today, after a factory reset of the RS 520 and deleting and reinstalling the Qobuz App (ver. 9.0.1) onto my iPhone / iPad, the glitch remains.
Others are experiencing the same issue. It renders Qobuz Connect useless at the moment.
A fix should be applied as an absolute priority.
Yesterday after a factory reset Qobuz Connect worked fine without any âstutterâ, today itâs not working at all
I quit tryingâŠ.
Thank you for adding Qobuz Connect.
Unfortunately, there are issues, at least on my 250.
âą everything is fully updated: both the app and the player. Latest firmware and latest app update.
âą also tried logging in and out of my Qobuz account a few times.
âą songs still skip randomly. No pattern.
âą gapless playback no longer works. There is a bit of a âskipâ for a few seconds from one track to another until the next song finally starts to play correctly.
This is really frustrating. It has been months since I have been able to enjoy Qobuz properly. There are always skips and random issues. I am very close to giving up on Hi Fi Rose altogether and selling my unit. I was hoping Connect would fix all of these issues. No such luck.
I stopped too, when it works (if it works!), it does not last.
We just have to wait for a reaction from the team Rose who must work on it surely, I hope.
Fully agree with you
Lamentable âŠtout est Ă jour chez moiâŠQobuz âŠle Rose RS130âŠmon smartphone S24 UltraâŠlâipadâŠle PCâŠ
For those devices with error message saying : Could not connect to media route,
Would you try Qobuz Connect again after turning off the âDaylight Saving timeâ?
Rose streamer > Settings > Date and time > Daylight saving time > OFF
Best Regards,
You can edit the name of ROSE device.
The name of the ROSE device is assigned randomly, and it seems that it was coincidentally named with âEAâ in this case.
Turn on your Rose streamer and tap the ROSE-EA on top left.
Iâm also having the same issue with my brand new RS130. I downloaded the new 5.9 update yesterday and updated the Rose Connect app. Qobuz Connect recognizes the RS130 but doesnât connect. That darn circle just keeps on spinning. I guess Iâm not quite ready to dump Roon⊠Itâs a shame they didnât QC this before the rollout
Hello @JayD ,
Would you check if Daylight saving time is turned on with your RS130?
Once you turn off the âday light saving timeâ, please reboot the Rose streamer.
(Press the power button for 5 seconds and tap reboot)
Best Regards,
Yes, I do have it turned on
I just turned it off and it still doesnât connectâŠ
Updated software to latest 5.9 Qobuz connect not working
I updated to the new 5.9 software and Qobuz Connect would see my RS130 but it would not connect. I turned off the Daylight Savings Time and it connected and seems to be working. I did not reset my RS 130, I just turned off DST and it began working.
Please turn off the daylight saving time and reboot the Rose streamer.
I turned daylight savings off and it worked for ONLY 30 minutes now it wonât connect again. Disappointing.
I turned off daylight savings time for my RS130 and my RS520 and performed a reboot on each. I was able to successfully utilize Qobuz Connect on both. I only played a track on each unit as itâs late here, but that is progress. Of course, now I display the incorrect time on both units.
Thatâs correct â this is only a temporary workaround, and we will identify the root cause and resolve it as soon as possible. We apologize for the inconvenience.
Additionally, for those who do not see improvement even after adjusting for daylight saving time, please check and share your ROSE ID.
(Rose streamer > Settings > System Info > ROSE ID)
If you are experiencing the error message âcould not connect to media routeâ when playing Qobuz, please check if the same symptom occurs even after setting it as follows.
Rose deviceâ> Settings â Date and Time â Daylight saving time â Off
Finally, reboot your Rose device
