RD160 Active Standby Function Not Working
Hi @ROSEHAN
I found my RD160 won’t go to sleep after passing the 2 hour period set by default.
I tried other settings, such as 20 minutes and 1 hour. The Active Standby function doesn’t work neither.
CPU version of my device is v1.20 and MCU is 1.0.1
Please help
Hi @TomT ,
To save time, check out this thread.
@ROSEHAN @ROSELOA
Apparently, several versions of the RD160 firmware have already been released.
I just read that TomT has his RD160 with version 1.20, mine is in 1.17 and others in 1.15
What are the differences between the different versions?
Why on HifiRose.com, only version 1.15 is available for download?
How to receive the latest Firmware? If it is useful of course, but if it is released it is because it must be…
I received mine today, I will check which is the software version
Thanks @VIK
I saw that post before. My previous RS150B and current RS130 go to sleep without any issue.
I normally switch off the DAC after use. But since the bug is found, I would like it be fixed in future update.
Surely this could happen since our locations and purchase times are different. But you are right that allowing users to update to the latest version should be an available option.
Version 1.17 on my model
Download version 1.15!!
What are the modifications and versions to take?
@Gillesbonatti
The current latest version of RD160 is 1.15. Version 1.20 will be released later.
Why do I have a version 1.17.?
foto portable
@Gillesbonatti
We will be releasing version 1.20 soon.
There is no significant difference between versions 1.15 and 1.17 at the moment.
