ROSE OS Ver.5.9 !?
Hi :wave:
I have just received an email from Rose announcing the release of « ROSE OS Ver.5.9 ».
Yet I cannot find any mention on the website neither on the community site.
My RS520 does not show anything (I run the latest AE).
Is this to good to be true an announcement that leaked ahead of schedule?
Regards
Stephane
Normally when you boot up your device, on the screen there should be a message like “there is a new firmware available, do you like to update yes or no.”
With my RS150b it was like that.
Maybe you have to turn off “use early access” to get the latest official one.
My RS130 it’s been updating to the new software for the last 90 minutes and still is stuck on the screen saying “software update do not turn it off” … What can I do? Should I keep waiting ?
Select roll back to official release and it will install the new one
Safely, can I turn it off? The screen does not show anything else other than the message. And logo.
I have just updated my RS520 to OS 5.9 and after this, eARC did not work properly anymore in combination with my Samsung TV. It worked flawlessly with OS 5.7, but with OS 5.9 the TV always switches back to its built in speaker when manually switched to HDMI output. Though the RS520 turnes on automatically when the TV ist switched on, the sound will only be played over the built-in-speaker of the TV. Really annoying.
However, I recognized that the new “eARC Always Connected” feature seems to cause this trouble. When set to OFF, everything works well again. When set to ON, the TV sound cannot be played via HDMI over the RS520. After switching the TV sound to HDMI, it automatically switches back to the internal speaker after just one second. Can anybody tell me the deeper sense of the ARC Always Connected feature and why HiFi Rose did set it to ON by default?
By the way, the current iPadOS version of the rose App crashes occasionally. Sorry, but does anybody at HiFi ROSE make some testings before publishing such erroneous software?
This might just be your specific machine and app.
Try installing them again and if the issue persists, or hopefully is solved.
Is there somewhere list of new addons , fixes and release notes? I didn’t receive it by e-mail.
Update went fine to me and my most desired new option - DLNA client finally works but has 2 bugs:
  1. Artist name is displayed as Uknown artist everywhere , titles (album and songs) are OK.
  2. Cannot control DLNA client from device , app only (Android)
Hi there,
Thank you a lot; I manager to update to the latest OS 5.9 doing a roll back on main software which instantly proposed me with the latest. Everything went fine.
This by the way got me rid of the thumbnail issue.
Thanks !
Stéphane
01. RoseTube Recommendation System
A music recommendation feature based on your listening data has been added to RoseTube.
It analyzes your preferred genres and listening habits to provide tailored content, including curated playlists specially selected by HiFi ROSE.
02. Qobuz Connect
Qobuz Connect allows you to select music from the Qobuz app on your smartphone, tablet, or computer and directly stream and control it on your ROSE device—without the need for any third-party apps. Your smart device functions like a remote control, while the actual playback takes place on the ROSE device, ensuring full enjoyment of high-resolution, lossless audio.
Key Features of Qobuz Connect:
· Full control through a single Qobuz app: Play music instantly without switching devices or apps
· Seamless device transitions: Continue listening smoothly even when changing devices or locations
· Support for FLAC lossless and up to 24-bit / 192kHz high-resolution audio
03. DLNA(Media Server) Playback Feature Added
04. Other Feature Fixes & Stabilization
· Applied exception handling for unplayable Qobuz tracks
· Fixed expired URL playback issue in RoseRadio
· Resolved thumbnail issue when pressing “Next” after “Pause” in Roon
· Fixed no-sound issue after Spotify Connect connection
· Improved playback error after restarting Apple Music app
· Fixed occasional crash when changing songs while viewing lyrics in Bugs
· Added title and guidance text to auto-scan network folders
· Added “eARC Always Connected” in Input settings
· Fixed malfunction when changing “Always Connected” in Input settings
· Fixed track info exposure after USB removal following DB scan
· Added error handling for CD ripping exceptions
· Fixed issue when ripping multiple CDs consecutively
· Increased character limit for Title/Artist editing to 2,000
· Improved MUTE behavior when volume is unsupported on RS130
· Changed LCD OFF icon on RS520
· Fixed artist name truncation issue on RS150 album/playlist screen
· Fixed partial image display in RS130 digital photo frame clock mode
· Resolved app crash when saving edited digital album in clock mode
· Updated description for FIR interpolation phase filter in OUTPUT settings
· Fixed German time unit typo (Stunde → Stunden)
· Corrected abnormal subscription icon display in RoseTube tabs
· Fixed subscription icon showing during RoseTube search
  1. RoseConnect Premium – Android
    · Playlist titles now display in two lines under “Search → Playlists → View All”
    · Fixed “+” button not working when setting amp volume
    · Added auto-scroll to item detail pages
    · Fixed focus issue on Queue screen when playing from Tidal tab
    · Strengthened null-check on folder navigation under “Music”
    · Removed PlayURL for third-party app usage
    · Changed “Currently connected device” to “Recently used device”
    · Added auto-update for IP changes in previously connected sets
    · Added USB Audio Volume Control in USB output settings
    · Fixed FM radio playback error when entering RoseFM
  2. RoseConnect Premium - iOS
    · Fixed crash when selecting result after Tidal search
    · Resolved issue preventing Favorite Album/Artist search
    · Fixed incorrect content opening after accessing search screen
    · Improved My Page search UI (applied white background to text field)
    · Enabled Apple Music Recent and artist name search
    · Fixed default volume operation issue on full playback screen
  3. RoseConnect Premium – PC/MAC
    · Added and stabilized features for 4th-generation Rose S/W integration
Since updating my RS130 to 5.9 I have lost the Roon Album artwork display. It shows the track information but no album artwork. This is rather annoying - is there any way to get it back?
I did a full reboot of the RS130 from the Rose Connect app and that has fixed the issue - please consider this s non-issue :slight_smile:
New official 5.9.02 Version including XMOS update afterwards.
With Qobuz connect listening to an album, following the next title, each beginning of a track “stutters”.
Together with a very short cratching noise.
This one is very important to solve quick !
So, no one else has issues with the new “eARC Always Connected” feature set to ON?
Can anybody tell me what this feature is all about? Since everything works fine with my RS520 when it is set to OFF, I would like to know its purpose.
For me, HDMI ARC/eARC is very important, since I always watch TV with the sound being played over my RS520.
@dtp
The “eARC Always Connected” feature keeps the HDMI eARC connection active even when the RS520 is in standby mode.
This can help ensure faster and more stable audio connections with your TV.
If everything works well with the setting OFF, you can keep it that way.
But if you experience any ARC/eARC issues, turning it ON may help.
Hello Rosehan!
I have an RS250A. Is this update worth it, or is it geared toward new products?
My current version is 5.7.07.
I look forward to your feedback, thank you!
I have the same problem with the same combination.
If I have the RS520 in standby, eARC is not working. I have to shut off the unit and restart the Amp. Why ist that. Before the release, everything was perfect …
In my case it’s exactly the opposite. SONY TV. Finally I can set the equipment so that if ROSE is off the sound comes from the TV speakers and when it’s on - it switches to the HiFi speakers. It works as it should, in previous versions regardless of the settings, the amplifier always turned on, which was not good for me.
@ROSEHAN were do I find this setting? haven^t found it yet.
Best regards
Alain
Witam.Czy ktoś ma problemy z uruchamiianiem się Rose 150B po aktualizacji 5.9.Moje urządzenie czasami nie chce sie uruchomić tylko pojawia się logo Rose na wyświetlaczu i znika,słyszę też stukanie przekaźników/urządzeń w obudowie Rose.Po wyłączeniu z zasilania i ponownym włączeniu,urządzenie się uruchamia ale o wiele dłużej niż przed aktualizacją,dłużej nawet chyba niż na początku.
Hello. Does anyone have problems with starting the Rose 150B after the 5.9 update? My device sometimes does not want to start, only the Rose logo appears on the display and disappears, I can also hear the clicking of relays/devices in the Rose housing. After turning it off and on again, the device starts up but much longer than before the update, probably longer than at the beginning.
