Starting situation
iPhone 17
iOS version 26.1
Rose App on iPhone: Vers.: 5.09.44
IP-adress (Wifi) of the iPhone: 192.168.2.22
Rose OS 5.9.09, Rose Ware/-Service: 5.9.07.1
IP-adress of the Rose 130 device: 192.168.2.46
Note: I also have an Android-based remote control.
Bug description
often when starting up, the RoseConnect Premium app on my iPhone does not recognize the RS130 device. When I finally manage to connect to the iPhone (for example, by turning Wi-Fi on and off), the Rose app on the iPhone loses contact with the RS130. When the app loses contact with the RS130, it displays the message: âRose â Connection error.â The Registering ROSE mode also cannot find the RS130. Manually entering the IP address of the RS 130: 192.168.2.46 usually does not help either. By the way, this error does not occur with the Android-based remote control.
The situation is very unsatisfactoryâcould you help me or give me some advice on the configuration?
The choice is simple.
