Any reason why I can’t select AES/Coax/Optical/I2S on the device? It’s greyed out.
Remove your usb cable and you can select it
Nope. Only I2S plugged in
Then why it detects a Holo Audio on USB?
That photo was taken with USB, AES and I2S plugged in. When I remove all cables, HDMI becomes selected and USB available. In every instance I have tried AES/Coax/Optical and I2S are greyed out. Rebooted million times and no luck
I did try and with all cables disconnected I can select any output without problems except usb
When I choose usb I get a message there is no usb dac detected
So I guess there is something wrong with your hardware
Thank you for helping. I’ll get in touch with support.
I updated device to 5.2 early access firmware, did factory reset and still can’t select AES as an output.
Since this issue is not recognized by XMOS, it does not seem to be resolved with a software update.
thank you for getting in touch.
on my RS130 which is working normally XMOS is 3151. 0000 doesn’t look right at all!
Thank you for checking
@MRD
The device can only be repaired by a distributor in the country of purchase. I will forward your symptoms to our UK distributor, HenleyAudio.
Please send the information below to my email address.
I have emailed all the details but haven’t heard back from you or Henley Audio.
I forwarded your email and symptoms to Henley Audio and told her to contact you.
Have you ever contacted Henley Audio? They say you never contacted them.
I have given you her email and contact information. Please check your email.
