RS130 using Roon, Pause button forwards to next song
RS130 using Roon, touching the screen or top button the play pause button forwards to next song and will not stop the music or pause the music. Using my other 5 streamers with Roon I don’t have this issue if I turn the RS130 off the issue goes away and the Play Pause button in Roon works again.
@ROSEHAN Any help with this issue is appreciated
@Michaels1963
Here are a few things to check.
  1. Does the same symptom occur when you reboot your RS130?
  2. When you play a source on another RS130 other than Roon, does it forward to the next song when you press the play/pause button?
  3. When you press the play/pause button, does it forward to the next song without any errors?
Yes @ROSEHAN it happens when I reboot, power down power up and after I unplug the unit for 24 hours and power up it continues to forward to the next song when I press play pause.
It will play music from my local NAS the play pause works normally and pauses the music and plays the music.
I have 6 other streamers in my Roon eco system a Denafrips Arce, PS Audio Airlens, Sonore Optical Rendu, Sonore Ultra Rendu, Wiim Pro Plus, Wiim Ultra that do Not act this way so if I power down the Rose RS130 streamer they all preform normal and pause play the music as normal when the Rose RS130 is powered back up the pause play button will again forward to the next song
@Michaels1963
Currently, this symptom does not appear on our side.
Please check if the same symptom occurs after reconnecting your RS130 to Roon after factory reset.
If it does not work after trying the above, please let me know.
I did a Full Factory Reset to the RS130 with no changes to Roon and then Roon found the RS130 and it now is working well.
Thanks for the Help
@Michaels1963
I’m glad the issue is resolved.
If you encounter any other issues, please let me know.
