RS130 won't output Native DSD on USB Output
No such thing exists.
Native DSD is… DSD.
Maximum rate of DoP DSD transmission is determined by the max PCM rate DAC accepts.
BorisM, I don’t get intention of your comments.
Premium USB cables exist if you have access to copper mill, extremely expensive machines, engineering knowledge and techniques developed over the years, creating cables by your own hands. What impact that cables have on sound quality is another story. I just wanted to point out that the cable is not the cause of the problem. Of course, the cheapest available cables should work as well.
Native DSD is the option selected in RS130 for transport method for DSD signal. And Native DSD is indeed DSD, again I am missing your point.
You are right about technical explanation for DoP DSD transmission rate. I am aware of that.
If you are able to help, you are welcome!
Thanks ZABOKS! I appreciate your reply and testimony that RS130 is working with your MSB DAC. I can only assume the problem is related between RS130 <-> DA2 DAC communication protocols. I can only see that McIntosh DA2 DAC states:
Additionally, the DA2’s USB input can support native playback of up to DSD512, surpassing the DSD256 limit of the DA1. here:
What is happening under the hood I am unable to understand without ROSE support help.
Thanks again!
Well, exactly. There are two types of USB cables. Ones that conform to the USB specification, and ones that do not. That is not in any way correlated with price of the cable.
So where does PCM conversion come into play?
This might be something where Rose would need to provide real help, but generally Native DSD works well from Windows if you have a device driver from the manufacturer. From Mac there is no Native DSD at all (with possible rare exceptions of manufacturers going to trouble of writing custom drivers). On Linux there might be Native DSD support for some devices if proper drivers were baked into the kernel. Since Rose runs Android, so basically Linux, there may be some DACs that RS130 can recognize and know that they can handle Native DSD , but as a general case I would look for confirmation from Rose that it even should output it…
I wanted to translate what my German friend said above. The RS130 puts out DSD bit perfect over USB 2.0. Only encapsulation is DoP v1.0, which doesn’t mean the actual stream is PCM. Paul McGowan from PS Audio wrote an article about this.
I guess in the pic above you can see that the RS130 does play the music file in DSD512 (that’s my comment). Also, I noticed that the volume is a lot lower when comparing max PCM and DSD playing through Roon.
I am not sure if this is correct though. Feels like I wasted a lot of $$ on the RS130. When I use a $170 Raspberry PI4 plus RoPieee software I built, I get native DSD to my DAC. With the $5k Rose RS130 I get the DoP Encapsulation. Sad to say, the little Raspberry sounds a lot better.
Raspberry:
RS130:
It must be a configuration problem as my RS130 can output native DSD…
I believe I know all the configuration options / screens and hence wouldn’t know what to configure differently . Btw, other than max DSD rate, the options are configure exactly the same for the above two steamers with different outcomes.
Did you try the USB3 ports as well ?
Yep… no difference. Thx, though. At least I am not alone with this issue as there are many threads about the same issue.
How did you connect your ROSE 130 to your DA2 DAC and what firmware version are you running. I can’t get the ROSE 130 to recognize my DA2 DAC. It’s running v5.02 on my C53. Currently I’m using the Coax connection.
I’ve ordered a iFi iPurifier3 to see if this will resolve the issue.
James
@jth1911
  1. RS130 has 3 USB ports. Is your DAC not recognized even when connected to all USB ports?
  2. Is the USB external hard drive not recognized when connected to your RS130 USB port?
  3. Even if you connect another external DAC to your RS130, is it not recognized?
  4. Have you changed the input setting to USB on RS130?
  • I’ve tried the McIntosh DA2 in all three USB ports. DAC was not recognized.
  • An external hard drive was recognized when plugged into the RS130 USB port.
  • My MSB Direct was recognized by the RS130.
  • I’m not sure what you mean by changing the input setting. I’m going to the I/O setting and clicking on activate the the port. It states no DAC.
I am in the process of choosing either RS130 or Lumin U2. I have a large library of DSD materials ranging from 64 to 256 (only 1 512) stored on an external SSD HD. Based your screenshot, you don’t seem to have an issue with outputting DSD natively via USB with RS130. I like to go with RS130 but playing back DSD natively is important to me.
Is my setup similar to yours? People experiencing the issue with lack of DSD native output via USB, are they caused by Roon? I am not using Roon.
My DDC and DAC are Denafrips Gaia and Terminator 2. My current streamer is Auralic Aries G1 and is connected to Gaia using USB which then connects to the DAC using i2s.
Any insights you can share are greatly appreciated.
Many thanks,
Tom
Yes indeed : No problem playing native DSD through my MSB Diamond V DAC, using RS130 SFP USB output connected with optical fiber first to ROSE RSA720 USB hub, then to MSB’s USB input with a short standard USB câble !
I guess you could connect your RS130 via USB the same way to your GAIA DDC, with a better SQ than using i2S directly…
Thanks for the quick reply. If you connect directly to the DAC using the “USB-DAC” USB port at the back of RS130, I wonder if it is still native through this port. If not, then the native output enabler is the connection to the DAC via the RSA720 using the USB 3.0 Fibre port at the back of RS130.
I really want to choose RS130 but want to be 100% sure.
Thanks once again.
Yes, before I got the RSA720 hub, I was also native to this usb-audio port with my Terminator :wink:
(i2s too!)
@zekor I was just describing my setup and I’m happy @musiq can testify that native DSD can be output from the RS130 to your Terminator, directly by USB.
By the way the RSA720 is only a USB HUB : it has no DSP to modify the data format, so if native DSD can be played, it is coming for sure from the RS130.
Many thanks for sharing your valuable insight. Much appreciated.
Thank you very much. I am now feeling much more at ease with RS130’s native DSD output capability. I guess a follow up question would be the improvement by adding RSA720. What’s your experience?
Kind regards,
Tom
