[RS150/RS201/RS250] [OTA] SW Ver 3.8(Rose 3.8.11) OTA Release
SW Update Notice
Applied Model : RS150, RS201, RS250
Ver info :
Applied SW Ver info Products
SW Ver v3.8 (Rose 3.8.11) RS150, RS201, RS250
MCU v2.0.29(M) / v2.0.45(A) RS150
v2.1.7(M) / v2.3.27(A) RS201
v2.0.22 RS250
RC for android v3.8.11.2 ROSE Connect Premium
-. Major additions/changes
  1. Input/Output Settings
  • Add PCM Resampling Frequency > Max Sample Rate
  • Added lower 8-bit correction menu for 32-bit sound sources
  • Added Phase Invert menu
  • Added FIR interpoation phase Filter menu
  • Pre-out output level step change (RS150, RS150B)
  • Added stabilization related to external USB DAC compatibility with Native DSD support
  • Improvement of pop noise that occurs when changing songs while using Native DSD playback mode when using an external USB DAC
  • Improved to detect sampling information in case of optical input that does not include optical input related sampling information
  • Added max sampling rate option and 24bit output mode for DAC users who cannot receive 24bit 192Khz or 32bit 192Khz digital output
  • Improvement of pop noise when changing FuncMode (RS250)
  1. Rose FM
  • Optimizations related to channel movement/playback and focus
  • Set channel playback and noise related stabilization
  • Added BT RCU focus UI and motion function
  1. CD Play/Ripping
  • Improvement of CD playback instability when changing output settings during CD Play (RS250)
  • Improvement of intermittent playback not working during Kobooz playback during CD Play
  • Stabilization of CD Play status initialization
  • Optimized CPU share during ISO Ripping
  1. Wifi Static IP Setting
  • Added setting function as Static IP after Wifi connection (DHCP)
  1. System stabilization
  • Improvement of ISO not playing in network folder
  • Improvement of error when scanning folders made as network folders public
  • Improved media scanning performance related to CUE files
  • Added analog output relay control option menu when switching audio settings > input mode (RS250)
  • Improved clipping when playing DSD (RS201)
  • wv extension sound source list display and playback support
  • Changed to display wav file sound source information
  • Improvement of digital input signal L/R change
  • Airplay thumbnails disappear and do not change.
  • Improvement to change the device name from 7 digits to 10 digits
  • Changed login conditions related to SMB spaces and special characters
  • Changed so that the image is not paused when LCD is OFF during Rose Tube playback
  • Fixed the issue of disconnection after completing Airplay album playback
  • Fixed an error when playing Webtube on PC Connect while playing radio
  • Translation applied to untranslated phrases in each language
  1. RoseConnect Premium
  • Tablet UI and landscape/portrait mode support
  • Fixed an error when playing NAS videos in RoseConnect
  • Improved to be displayed in recently added albums (RoseConnect) after CD ripping
  • Added refresh function at the top of CD tab
  • Added input/output setting menu (8-bit correction/Phase Invert/Phase Filter)
  • Change the device name to 7 digits → 10 digits
  • Fixed search icon UI when logging out of Bugs, Tidal, and Qobuz
  • Improved the album name not being edited when editing album meta information
  • Improved the phenomenon that titles and artists disappear when scrolling left/right of recently added albums
************************** Manual Update *****************************
If there is anybody who can’t update from online, please see the Manual update as followings.
Download link for USB update.
  1. Prepare a USB memory stick formatted as FAT32.
  2. Download the update file by clicking the link corresponding to the product model you have. (This is a zip file. Do not unzip and edit file name it.)
  3. Copy the downloaded file to a USB memory stick.
  4. Turn on the product and insert the USB memory stick into the rear USB port.
  5. After a while, you can update according to the update guide message on the front LCD.
RS150/RS150B : rs150_update.zip - Google Drive
RS201 : rs201_update.zip - Google Drive
RS250 : rs250_update.zip - Google Drive
Good afternoon Community
I’m quite enjoying my hi-fi rose RS 150. This update was pushed out a few weeks ago I applied the update.
When I’m in Tidal changing tracks I hear a ignoring pop noise it wasn’t there before on last update but it’s there now.
Update suppose cure a number of things it hasn’t done so.
I’ve noticed there is some new features
Added Fir interpolation phase menu.
Could we have a better understanding about this particular menu.
Still no tablet ui landscape/portrait mode support.
Just wondering if anyone has had the same problem as myself
Hello @Edward57 ,
  1. Tidal pop noise
  • How is your audio system organized? RS150 -(USB)- DAC - AMP - SPK? Or do you use internal DAC of RS150?
  • If you use external DAC, can you tell me the name of the model?
  • Does the pop noise happen everytime? Or sometimes?
  • Does the pop noise happen with your local music files and Rosetube, radio? (Or only with Tidal?)
  1. About added Fir
  • We will explain separately
  1. Tablet
    Which tablet are you using? Can you check if your app is on the last version?
Hello
Thank you for your reply
My system RS 150 using internal DAC with a-pair of audiolab monobloc 8300MB using XLR cables.
You can hear the pop noise when you’re skipping MQA tracks. NONE MQA tracks you can hear the pop noise sometimes.
on my local music files you can hear the pop noise sometimes.
I’m using my iPad Pro tablet I’m running the latest version app.
Many thanks
Hello
I’ve downloaded the file corresponding with my RS 150.
I applied for the update as instructed. Open up Rose premium run tidal played a MQA track pop noise still present.
When I play and Audrey file from tidal no pop noise.
It seems the noise happen when you are playing a MQA file.
Matter of interest will there be firmware update for Tidal connect.
Many thanks
Hi
As a newbie, can I have better understanding of what each phase filter means? It’s effects on sound signatures?
Thank you in advance.
