I just purchased a RS150B and I have two issues related to Roon,
(1) I cannot see RS150 as Roon Ready device. I can only see it as Other network device via airplay. Why is that? Is there any setup needs to be done?
(2) I connect a Raspberry Pi NAA (running Moode) to RS150, and when I try to play music in Roon with output to hq player, the hq player went on only few seconds without any sound and then stop. moreover, I noticed that HQ player cannot recognize the NAA anymore, I need to restart the NAA again. What is the possible cause of it? By the way, I used to use this same NAA to connect to a very old USB DAC and it just works fine without any problem.
Please advise what should I do to resolve above issues.
Thanks, Edward
