RS250 briefly shows Home Screen when switching to next song
Like the title suggested. The playback screen (I usually uses album cover view) would flash back to Home Screen if I press next song. This behavior only happens when using Roon, playback screen stays on with the native Rose music app. This started since last update. Please fix it @ROSELOA .Thank you!
  1. Did you skip to next song on ROON app?
  2. You said it happened after last update → does the last update means the update from last yesterday?
    (ROSE OS 4.1.03)
Thank you,
1: Yes, it only happens to Roon but not to Rose app.
2: It happened after the update before yesterday’s. In other words yesterday’s update didn’t fix this problem.
Thank you!
I will check it, thank you.
