RS250a Constant Reboots Needed with Roon
@FrankP
It is currently under review. I will leave a comment as soon as it is updated
No I got a similar problem with the RS451.
What I’d done before the problem occurs:
Switched the output from analogue out to usb out and tried then playing something through Roon.
Local playing and Rosetube plays, but Roon not.
It needs a lot reboots and in the end also an Roon reboot for fixing it temporarily.
Tried it now again using the RS451 as roon endpoint, but it doesn’t work.
What seems to solve the problem: Deactivate in Roon the device and reactivate it again. Now I’ve checked ten times
  • playing from Roon
  • put the Rose into standby
  • tell Roon to play again or another file
    → working again.
It seems, that switching the output (I’ve done this formerly sometimes with my RS150 without problems), which changes the max audio resolution for the roon endpoint doesn’t works further more.
@burki
The issue has been identified and is undergoing testing after being patched. If you send us your Rose ID, we can enable your device to receive the fixed firmware via OTA prior to the general F/W deployment
@Rose_love Does the patch apply to my issue as well?
@FrankP
If you would like to test the fix for the Roon playback issue before the official version is released, please send your Rose ID (Settings > System Info) to the email address below. We will then send you an email with instructions on how to update.
(shim1691@citech.kr)
@burki
I’ve send you my ID for the RS451.
@Rose_love :Thank you for your prompt response. I will only be able to send the Rose ID next Wednesday, as the device is located in our second home 800 km away.
Mmh, no answer from @Rose_love
In Korea it‘s 22:30 pm now :wink:
Send the email for over 9 hours ago and he asks me multiple times…
@burki
The email address currently registered in the community is different from the one received by @Rose_love.
When you send an email to the address below, please let us know which nickname you are using in the community.
shim1691@citech.kr
@Rose_love : you‘ve got mail :slight_smile:
@Rose_love The roon-problem has been fixed with the update. Thank you very much!
@FrankP
Thank you for your reply.
The firmware we provided will be included and released in the next official version.
@Sirpopealot
It appears that updates have been made regarding version 2.61, as mentioned in the Roon Community post below. You should be able to use the official version on your Hi-Fi ROSE device without any issues. Please let me know in the comments if you encounter any problems during use.
