I just recently got the rs520 and it seems great so far but not perfect when it comes to the AirPlay implementation. Is there any way we can fix the following:
No album art when Airplaying from a Mac to the Rose.
Missing album title when Airplaying to the unit on the display.
No track time/progress or track number.
Can these get fixed? It’d be perfect if we can get these.
Are you sure that’s the case? Any type of Sonos device seems to support this. Can’t you have it so the volume that’s on the iphone in this instance is mapped exactly to the Hifi Rose volume? Having two different settings is an enormous pain.
What kind of music source does the album art not display when playing on a Mac? Tidal, Qobuz, Apple music, USB storage sources, etc.
If you are talking about the phenomenon of album art not being displayed when playing songs stored on a USB external hard drive or SSD, it will take some time to fix it.
When playing music stored on a USB external hard drive or SSD, all album art is not displayed? Or are some displayed and some not?
I’m talking about what I mentioned above. If from my Macbook Pro, I airplay from Apple Music to the RS520, there is no album art. If I do the exact same with the same music on my iPhone, it works.
To say, this isn’t streamed music, this is music that I ripped from CD to Apple Music in the past. So to further clarify:
Apple Music (Macbook Pro) > Airplay > RS520 = No album art appears.
Apple Music (iPhone) > Airplay > RS520 = Album art appears.
You mentioned here above that it was meant to be fixed:
I checked the information again and found that when using Apple Music on an iPhone, the album art is displayed when connected to AirPlay. However, it does not appear when using it on a Mac.
This can be reflected if Apple improves this area in the future, as album art is not supported even on Apple devices when using a Mac.
It appears that what you’ve said there is completely inaccurate. Here are two examples. The first is my iPhone Airplaying to my TV which supports Airplay:
Sorry I don’t understand, how does Apple need to improve here? I’ve shown that going from a Mac > TV in that example shows the album art. It seems like in the instance of the RS520, it’s not even though going from iphone to the unit does work.
