RSA-780 ripping CD is very slow
I now have a problem when ripping CD to my laptop, it takes on average 35 minutes for one CD when it use take 7 minutes in the past. I have this unit for only 10 months and it is now giving me trouble. I tried with another cheap CD player and it work flawlessly with 7 minutes or so. Considering ROSE RSA-780 is kind of expensive I would expect better quality and reliability. Am I the only one with this problem and can someone help me with fixing this problem?
You could maybe run a CD lens cleaner in it and see if that helps.
Also, what software are you using for ripping? It might tell you why it is being so slow.
@Carjo
If the RSA780 now takes much longer to rip CDs, please try the following:
  1. Connect the RSA780 directly to your laptop’s USB port (not through a hub).
  2. Try a different USB cable or port.
  3. Use a CD lens cleaner to remove any dust on the optical lens.
  4. Test the RSA780 on another computer to see if the same issue occurs.
Normally, one CD should take about 6–8 minutes to rip.
I have the exact same problem, but to my Rose 151
@HERMAN1217
Under normal conditions, CD ripping typically takes less than 10 minutes.
Please check the following details:
  1. RS151 system version information
  2. Check if the same issue occurs when ripping CDs with a different CD-ROM drive (other than the affected one)
  3. Does the CD ripping eventually complete despite the delay?
Please provide any additional details about the issue, and we will look into it further.
Software updated to XMOS 5012
I think i have found the problem.
The cd drive spins for a few seconds then stops, and then it does it again. This is why it takes over an hour to rip a cd. To test this theory, I try to play a physical cd. It takes a long time to populate the screen, and when it does play it only plays for 1 or 2 seconds then it spins some more.
Foot, note I have ripped over 300 CDS in the past
Herman Eilber 954 695 0324
