I am using RS130 with fiber connection to RSA720 and connect the RSA720 USB2.0 port to DAC, the RSA720 switch has turned to SFP mode.
Recently, when I power on the RS130, and then the DAC, for most of the case, the RS130 cannot detect the USB connection of the DAC. Sometimes I have to restart the RS130 and then my DAC or vice verse in order to get the RS130 recognise the DAC which is quite unpredictable… thought after several attempt it should be fine, but again, this is unpredictable and inconvenient.
My DAC is Weiss DAC501 MK2
I also check around the Rose community there are plenty of users here experience similar issue and some of them even can’t make it work and have to return it…
May I know if this is being aware and investigate behind the Hi Fi Rose engineer?
May I know if fix is under development?
May I have your insight of this issue?
Thats fine if this is the pending issue of Hi Fi Rose if this has been well aware by Hi Fi Rose engineer and wish to know if any action was undertaken inside Hi Fi Rose!
Thanks alot!
Deckard
