I’m still experiencing random skips of tracks. Logged out/ back in, factory reset, playing from Tidal still the same. It doesn’t happen anywhere else apart from my RS250! 🤦
We are checking if the issue occurs by logging into various Qobuz and Tidal accounts on various Rose devices.
We will continue to play Qobuz, Tidal audio and check again.
I have a question.
Do you get a pop-up error message when a track skips to the next track?
If so, please tell me what the message says.
Additionally, please let me know if the message occurs when you go into your mailbox by looking at the picture below.
Same here : no message, just skip to the next track !
Same problem here too with Qobuz : no message, just skip to the next track !
It happens also after resuming from a pause for a few minutes (for answering a phone call) on a track… It plays a some time then skips to the next track. Erratically and more often after this manual operation… But not systematically !
Definitely no messages regarding skipped tracks.
We have also confirmed this symptom, and the development team is currently checking and fixing the symptom.
We will fix this issue as soon as possible and reflect it in the next update.
It seems that, after the recent update, the problem has been solved. My RS150B has never skipped randomly to the next track when playing Qobuz in these ten days. It is curious because this concrete issue doesn’t appear explicitly in the list of fixed problems.
Many thanks to Rose anyway.
