Specification for HIFIROSE models
Uploading the specification comparison table so you can compare comfortably and make the right choice for you.
Click and click again the image to enlarge.
Visit HIFIROSE HOMEPAGE and check detailed information.
Which remote APP should I use?
  • RS150B, RS250, RS201 → ROSE CONNECT PREMIUM
  • RS301, RS350 → ROSE CONNECT
RS301 and RS350
RS301 and RS350 are ‘all in one’ models, including speaker. They use different ROSE OS and remote APP.
RS301 and RS350 are no more sold to countries other than South Korea.
*First written on November 25, 2021
Also, thank you @aswiss for your effort!
