There is no discussion to be done with the militantly ignorant, and you obviously haven’t bothered to familiarize yourself with TomTurd’s oeuvre.
Where are you at with your research Tom? I’m thinking I may pick up a Ref10 nano. Although I think some people are nuts with using a clock for their router/switches, in all that I’ve read, I haven’t found anyone who actually tried it, saying that it didn’t make a difference or made anything worse. I’m too curious to let it go, it seems.
Hi, I didn’t go further, cause I am considering selling my Rose gear as the company doesn’t really care about its customers.
I have a LHY SW10 and use its clock as master for the RS130 with good result. A friend has the LHY OCS-2s which is even better (it has an even better clock). Beware, the clock cable makes a difference, so buy a quality one with good audiophile references.
Ah, yea, the software is quite bad, and its a shame since their parent company is a user interface company. Kinda crazy. Really wish they would open source it so the community could build something since they are not willing to fix or improve anything.
What are you considering as a replacement?
I’m not sure I buy into the whole high-end clock cable thing either. A solid core copper wire in a wire mesh shield cage at super short distances cannot be that different from each other.
I am considering the Auralic, who have some good new products. Or may be Eversolo or MX. These three are from China with relatively good reputation in sound quality.
Comme je l’ai dit plus haut, une simple horloge à 240$ fait mieux que l’horloge interne du Rose RS130 /
https://www.thanksbuyer.com/model-v-10mhz-ocxo-ultra-low-phase-noise-ocxo-with-sma-bnc-interfaces-and-2-way-isolated-output-89708
et un petit câble BNC à 3$ suffit (mais il faut qu’il soit très court…15cm)
@TomT…J’ai testé le DMP-A10 d’Eversolo…c’est un excellent appareil, mais lorsque qu’il est utilisé en streamer ,pas tout à fait au niveau du Rose RS130
Oh, but they absolutely can. Cheap BNC cables can definitely cause issues with signal transmission and result in your device showing errors. I’ve tested very inexpensive generic BNC cables under 1 meter, and they were problematic—poor connectors and inconsistent performance made them unreliable. Sometimes they worked fine, other times the receiving device displayed an error. Switching to Sommer cables resolved the issue immediately. They’re not overly expensive and performed just as well as some of the higher-end cables I tested.
In the end, I opted for custom cables because I wanted specific lengths, premium connectors, and more flexible cables that weren’t overly stiff. So while I don’t think it’s necessary to spend $200 on a cable under 1 meter, I also wouldn’t recommend going for a $10 cable if you’ve invested in and plan to make use of an external clock.
I thought I’d start with trying out these: https://www.aliexpress.com/item/1005008450689965.html
For those of whom this is of interest:
Vid is in Dutch, so please use subtitles for all other languages.
Interesting. Which cable model did you go with?
Just got a Ref10 nano, and set it up last night. Whoa! I was skeptical, but pretty sure this isn’t in my head. Sounds spectacular! Running the RS130 and RD160 via SFP fiber.
Boris…I’ve come across this forum and all I’m seeing is bitching out of you and pissing off other members. Take a chill pill and try to be nice and if you’re married I really feel sorry for your wife or partner.
Or… you could try not posting BS. But that might be too hard for the militantly stupid crowd.
Nice to hear. Enjoy your new setup and maybe think of a switch with clock input further on.
Feeding my REF10 Nano and SoTM SNH-10G Switch (2 SFP Slots, clock input) with Keces P6 Linear Power Supply.
From my router i go with Audioquest Vodka Ethernet cable to Trendnet TFC-1000MGA.
I tried some fibre cables and converters (Finisar) they have their own characteristics.
Give the Amphenol DirectAttachedCopper cable between FC Converter and Switch a try.
The 2nd SFP Port i’m using Cisco AOC fibre cable to RS130.
If you’re interested in sources to look at and order, let me know.
Sideeffect to Apple TV4K Box connected to SoTM Switch…, after clock input here picture and sound on Netflix etc. even improved, more fun !
So I was skeptical about the clock in general, but now I see it makes a difference. The network switch I’m still not sure about. I did however just test back and forth, connecting my switch with SFP out from its original power supply to a lithium battery power supply, and there is definitely a difference. I don’t know what to think anymore haha. So many people online talking about how all of this is nonsense…
So I just ordered a Gustard N18 pro, since I can buy it on Amazon and return it if it doesn’t change anything. Anyone have experience with this switch?
On your recommendation, I bought a Keces P14. WOW, night and day difference when powering the Mutec Ref10 nano. Did not expect that
Thanks for the clock feedback, knowing all the science behind clocks will never be as conclusive as experiencing the improvement with your own ears.
I wonder if Rose will bring out a super clock in the future? but for now am very happy with the 130 as is…
