hi
I use a integrated amplifier connected to Rose RS150
When the amplifier alone turned on no humming sound could be heard through the speakers.
But when I turn on the RS 150 I can hear humming sound coming from the speakers When no music is playing.
The output level on the RS 150 9.0Vrms balance
Output level on RS 150 B 6.5Vrms balance.
yes my reseller told me it was compatibility I’ve tried three different manufacturers integrated amplifiers still the same humming noise.
It seems like when you buy a hi-fi Rose product you are literally on your own supposedly mine has been with the distributor for at least seven weeks No fault found so I’m told.
I am extremely disappointed with Hi Fi. Rose products.
