I would like to purchase a 4TB internal SSD drive for the Rose 150. What brand(s) are recommended for
Reliability
Audio performance
Thank you!
Jeff
Reliability
Audio performance
Thank you!
Jeff
Thank you very much Alessandro
Alessandro, were you able to enable the SMB share on the Rose? I get an error after i attempt to turn on, add a username, pwd and change the Workgroup to my own internal networks name. I get âFailed SMB setâ and never can access the Internal drive from my network.
Hi Jeff @taystnotes
I have had no problems letting my Mac connect to the Rose and I can see all my directory of Music files (primarily CDs ripped to the Rose) on it - I remember setting the SMB share at the outset and - since then - I didnât have to do much more. I also remember seeing a number of posts specifically on this topic here, if you search for it wasnât long ago and in that thread there were detailed instructions on how to make this work.
I have all sorts of problems with the data management and visualization of the ripped CDs files and its metadata/info on the Rose and on the App, but thatâs another storyâŚ!
The only part that didnât work as you stated is ââŚmake an account.â
I had to use a username âroseâ to set. I could not create a username of my own choosing.
Yes, thatâs a tricky bit that hasnât been explained properly. You must use the same username you use on the Rose to connect the SSD to your Mac (if itâs a Mac youâre using). So, use the same username you used when you first set up the Rose. Everything else will then connect easily.
Hello! Is it possible to use 8Tb SDD with Rose 150b? That would really be wonderful âŚ
Hello @bsauvage
We support SSDs up to 4TB. However, we do use SSDs with larger capacities for testing.
I canât say with certainty that an 8TB SSD will work.
thanks, got a 4TB and working great
Samsung EVO SSDs use TLC NAND (3 bits per cell) while the QVO line uses QLC (4 bits per cell). For reference, Samsung Pro SSDs are made with MLC NAND (2 bits per cell), but below, we will focus on the differences between the consumer alternatives EVO and QVO.
The lifespan of an SSD is measured in terabytes written (TBW), which tells you how many terabytes of data you can write to the SSD before it reaches the end of its lifespan and eventually breaks down.
You probably guessed by now that QVO drives generally offer a shorter lifespan than their EVO counterparts due to the fact that it writes four bits per cell.
There will be no difference in the performance of the R150 if you use a QVO or EVO
Just FYI, I am using a Western Digital 1 TB Blue SA510 SSD in my 150B and so far no issues. I appreciate how really easy it is to install. However, getting my music on it required two calls to Crutchfield customer support after being unable to transfer digital audio files from my laptop without assistance.
Transferring files music files to an SSD installed in a Rose product is definitely much harder than it should be.
