The Rs150b has a remote control with Bluetooth nail but no infrared control.
My programmable remote control only manages infrared.
This is the only small flaw I find at Rs150b
Gil
Gil
Gil
I suppose that you have Google Translate in France. Use it if you want english speaking people to respond to you.
? No one for this question?
By connecting the USB-IR gender cable to your Rose device, you can use the remote control without having to connect it to Bluetooth.
The USB-IR gender cable in the link below is compatible with Rose devices.
Excellent news.
Thank you, I’m going to test.
The Bluetooth Remote send also IR?
Yes, since it’s the same for the Rs130 that does both
Hallo
GS-R18E (RC850) ?
Would be nice, i want also use my programmable IR, but I Need the original IR-Code
I just plugged in an IR dongle and nothing happens. It doesn’t work.
wrong information from you.
i tried 2 dongle according to your recommendations and nothing happens.
i restarted the rs150b but the remote control does not work in IR
I have this extender ordered, it don’t work.
Please give us more Information
Your usb-extantion, perhaps don’t do it alone, Need a usb-ir too?
Which USB-Port?
Deactivare Bluetooth?
Further Configurations?
Greetings
An answer would be appreciated please
If you connect the USB-IR gender cable shown in the photo below to the USB port on the rear of the Rose device, you can use the remote control without having to connect it to Bluetooth.
That’s what I did.
Plug in instead of the original dongle and nothing happens
This is not the same usb you have linked before. Please Check it.
That was What you want us to
I forwarded the information to our technician.
When connecting the USB-IR gender cable to the USB port on the rear of the Rose device, the input frequency is 38kHz, so when purchasing a USB-IR gender cable, you must purchase a 38kHz model.
After we got a link with the wrong product, it would be nice to get a link with the right one
There is no separate link to the product.
We only have specifications for compatible products.
Is here anybody, who got this running and have me a link?
Hallo
I spend some Money for different IR USB-Adapter, Not one works.
Since @ROSEHAN can Not Even answer, which USB Port works, and there is no user to find, who got this working, this was a wrong Information from the begining.
Same Story like the Multichannel over HDMI
Greetings
