I HAVE A QUESTION on the xlr outputs on the 150b. I thought they were fixed and was not variable. AM i wrong ? TRYING TO HOOK UP TO MY INTEGRATED AMP. What menu do I use to change this if its adjustable?
Somewhere i say what to do about it.
Go to setting and click the gears for the analog outputs. Set Preout level setting to ~2V which is equivalent to the output voltage of all cd players so you don’t have to look up the input sensitivity of your integrated. Make sure Software Volume Control is off.
