Language suggestion
See the below menu. The articles “a” is not required or appropriate in these cases.
Also “Play from this music” is awkward. It should be “Play this track” or simply “Play this music”.
" Add a music" is inappropriate. It should be “Add music” or “Add this track”. Track is more colloquially correct than music in these circumstances.
See also “Add from this music to the end of the queue”. The more colloquially correct would be “Add this track to the end of the queue.”
@StandardModel
I have forwarded your request for revision to the software team.
They will review the content and make corrections.
For other language issues, see [Feature Highlight] Rosetube Recommendation System - #4 by joyofmvid
RoseTube sometime plays in the wrong language ← see PCM Delay Time Not Working! - #11 by ROSEHAN
posted in error removed by author.
In the Qobuz, Tidal,… apps rename “Rose Classic” to “RoseClassical” or “Classical”
See Issues with language on RoseTube
@joyofmvid
When you access Tidal or Qobuz in the RoseConnect app, there is a “Classic” menu at the top of the screen. Do you want to change it from “Classic” to “RoseClassical” or “Classical”?
Rosehan,
The word “Ensamble” above is misspelled. It should be “Ensemble”
@ROSEHAN - as well as ‘Ensemble’ kindly pointed out by @StandardModel, may I also flag:
‘Classical’ instead of ‘Classcial’
and
‘Conductor’ instead of ‘Conducter’
(proofreading free of charge…)
rose spelling
Yes, change “Classic” to “Classical”
I have forwarded the 3 typos you requested to the software team.
See [Ver 5.7] ROSE Classic
  • on #2 Artist Collection’s left-most screen, “Classcial” should be “Classical”
  • on #3 left-most screen, “relistic Sound” should be “Realistic Sound” (I don’t know what Reqlistic Sound is) ← if this is “live music” then rename “Realistic Music” to “Live Albums”
  • #3 middle screen, “popular albums” should be “Popular Albums”
@joyofmvid
See In RoseTube there is a grammar error
@joyofmvid
I’ve forwarded your request to the PC RoseConnect developers.
They will review it and revise the wording as soon as possible.
Here’s more:
“Rose Recommend Channel” should be “Recommended by Rose” .
Another comment : Three categories are of no relevance and aren’t accurate
  1. Rose Recommend Channel
  2. Popular Channels in Region
  3. Region Channel -duplicative of 2?
How about letting the user decide what to list?
@StandardModel
I will request to change “Rose Recommend Channel” to “Recommended by Rose.”
However, “Popular Channels in Region” and “Region Channel” are different.
“Popular Channels in Region” refers only to the popular channels in the selected region,
while “Region Channel” refers to all channels available in the selected region.
FYC:
Change “Popular channel in region” to “Popular channels in xxx”
Change “Region Channel” to “All channels in xxx”
  where xxx is the current region
Also, before the “Recommended by Rose” group, enter “Favorite channels” group ← note: to enter this extra grouping, you may need to reduce the cover art size in all groups.
Thanks in advance
