|I have a new remote for my RS 520. I followed the instructions to pair the remote:
The new remote is not seen by the RS 520.
- I have installed new batteries which a voltmeter measures at 1.5v each
- I have attached and substituted several IR receivers to make certain they were not causing a problem
- I have activated the remote to be seen in the Bluetooth subsection of the RS 520 setup
- I have simultaneously pressed the home and options button until the light on the remote is solid white
- No remote is seen by the RS 520. Did I just buy a faulty remote or is there more I can do?
Hello Boris
Information: (I’m sure you all know this…you’re educated and well-read)
