[OTA] SW Ver 4.15.12 Software Release ( RS130/RS520/RS150/RS250/RS201 )
I got Qobuz working again via logging in through the iOS app, and now you’ve pushed out an app update and I can’t access Qobuz again!
Hifi Rose you need to resolve this asap as the situation is appalling and I am now considering selling off my RS150b to get a DAC with a more stable operating platform.
The 150b seems unable to pull any music from Qobuz and hangs and I have also lost access to some BBC radio services as well.
150 b now no longer works with Quoboz-reinstalled updated app-now just hangs -no music
You guys are ridiculous-worst update, no help, crowd sourced solutions.
Fix the quoboz access please.
Would never recommend this device ‘
Qobuz stopped working today. I can’t play any music anymore. I can’t see any music on the steamer but I can see everything in the app but when I click on play on my phone nothing happens. I tried to login a few times, did a system restart and even a factory reset. Nothing.
When I try anything in Qobuz on the streamer I keep getting the message: start qobuz for stable system operation.
This is very disappointing to say the least…
Fix it guys!
Hi all,
I have the same issue on my side.
Please fix it.
rs250 rose server gives not connect error and does not update
Login issues for Tidal have returned. Was this major release even beta tested? So many issues.
Hello,Rose Hifi
Even after last Tidal update i was kicked out from Tidal again and music stops.
With Qobuz i had the same problem as the previous one ,i need to login again when i try to use it.
Please fix it…PLEASE !!!
I don’t understand why is not possible to fix these major issues ,and go back to the previous free problem firmware.
I have the same question, why can’t I use the previous software if there are problems with the new software.
I got tossed out of Qobuz again today and had to login again.
Also when I type in a search query the app is very laggy.
I too have login issues with Tidal again. The problem is back now and not yet fully resolved. H
I also had to login into Tidal again this morning after yesterday installing the updates that were meant to fix the “ log out “ issue.
I deleted and reinstalled Rose Connect Premium app on my iPad today to see if this helps. So far, so good. Next bulletin tomorrow !
150b. rose app via iphone 12. primarily a tidal hifi user. everything working fine. mqa logo has switched to hi res audio logo on 150b and in app. no issues so far. thank you.
I have this latest update on iOS, but I must be a little slow. I can’t figure out how to install anything from Rose Store. When I hit the dropdown for something that is “Not Installed”, I just get an “Update” option and no ability to install it. If I select “Update”, nothing happens.
It doesn’t work, but you can install them on your Rose.
Also: they shouldn’t call it an update when you don’t have the app already installed and they should not call it remove update when in fact you remove the entire app.
Thank you Hans. Yes, I agree that terminology on the app is poor. It should not even show “Update” if it is not installed. The people who put this app together have a bit of work to do to make it more sensible.
Hmm. Hans, I can’t seem to figure out how to do as you say, from the RS130 panel interface.
I had the same experience and Tidal & Qobuz worked perfectly.
Hi Tony, on the screen of your 130: go to Rosestore. There you can find the apps you want to install.
Little swipe to tge right and there it was! :man_facepalming: Thanks.
After the last update, my Bluetooth on my RS520 s turned off every time after a restart and I have to turn it back on every time. Very annoying😣
