So far everything without problems.
As I have seen with some users, the update is not always offered. The solution is to completely turn off (not in standby) and restart the Rose.
I updated my 150b (from the EA version) and so far everything seems to be working fine. Thanks Rose team. And also good luck with the political situation in your country.
This was a smooth update on 150B
My Daniel Hertz Maria amp USB connection is still not working!
Hello, Hifi Rose people, thank you for the software update.
I have it installed on my RS250A, so far everything works fantastic; Please note that in my case I do not use the unit as a Streamer.
Greetings from Buenos Aires, Argentina.
Please fix it. Still almost 200 albums has genre as āUnknownā
Well done guys.
Girls too if itās the caseā¦
Every release brings new malfunctions. Software volume control malfunctioned and had to be disabled to get any sound. Now Playlists cannot be added to. Roseconnect will randomly lose connection and ability to connect. Queue list goes missing. Displaying folder content to make a queue or playlist stops part way through and will not load. Functionality was never well designed but now even that is mostly gone. By the time I figure out workarounds as we always have to do a new release with new errors will come out no doubt. It makes it very very very hard to use or recommend the product ( 150B)
rs-150b update latest version already but hdmi-arc canāt used.
please fix thankās
I can normally hear the TV sound through RS150b when I connect the TV to the HDMI ARC in port with the latest version of RS150b.
Please check a few things.
- Is ARC IN activated in the input/output setting menu of your RS150b?
- Does the same symptom occur when connecting with a different HDMI cable?
- Is the sound output on your TV selected as HDMI-ARC output?
thank you
@ROSEHAN : can you please provide an ETA for a new software release that solves (most of) recent issues?
Thank you!
Please request the latest version of the update file to the email address below.
When sending an email, please tell us the Rose device model name and Rose ID you are currently using.
Rose deviceā>Settingsā>System infoā>Model, ROSE ID
Hallo zusammen,
ich versuche nun seit einige Zeit das Update auf 5.7.07 herunterzuladen und zu installieren. Leider kommt nach dem Download immer der Hinweis āOTA failedā (s. Anlage). Was kann ich noch versuchen? habe bereits netzkabel getrennt, auf werkseinstellungen zurückgesetzt - hat leider alles nichts genutzt.
Vielen dank
Chris
Hallo Chris, hast du mal versuchst die early access version zu installieren? Wenn das klappt, kannst du (vielleicht) zurück nach offiziell.
Hallo Jobbie,
danke für die schnelle Rückmeldung. Habe ich aber auch schon probiert. Gleiches Ergebnis. Konnte ich ebenfalls nicht installieren.
GrüĆe Chris
Hallo Chris, schwer zu verstehen wo dass schief gehtā¦
Kannst du links unter auf die Abbildung (grün) nicht deines Apparat wählen?
Da gibtās übrigens nichts zu installieren! Nur spielen, entweder vom Handy oder Computer!
@Chris
Hallo Rosehan,
Ich habe Ihnen die Anfrage per Mail zukommen lassen.
Vielen Dank
Chris
