Problem LOGIN roseConnect
I have tried to login/register on RS-150 directly using the same email/nickname for the forum (see below). It said duplicated email or nickname. Apparently your system already has the required information. What would you suggest? Should I borrow somebody else email and try again?
Email: efykkwan@cityu.edu.hk
Nickname: FredYK
Check your email efykkwan@cityu.edu.hk
Hi. Unable to login. kalevasu@hotmail.com
Please check your email
Geachte,
HELP ik kan niet inloggen op mijn Rose250
Mijn email : De.kit@skynet.be
Het account is blijkbaar aangemaakt maar het wachtwoord wordt niet herkend.
Opnieuw de hele aanmelding doen gaat niet.
De Rose app verwijderen en alles opnieuw doen werkt ook niet.
Ik zelf denk dat de instructies niet duidelijk zijn gezien het feit dat veel mensen hier last van hebben.
Groet Manfred
Problem solved. Thanks a lot.
Would you please download RoseConnect Premium APP and try to ‘find password’?
ROSE APP > Setting > My Page > Find ID/Password
Thx problem solved
Thx a lot
Hello! I got the autentification email but the page displayed an error. Can you check my email: urtyp.xxx@gmail.com Thank you!
Hello, authentication has been successfully completed.
You can use it after logging in.
I’m sorry but the “-” doesn’t work in ROSE account now.
Could you please use a different email?
Also, the I’ll talk about the bit rate with development team.
Whatever nickname i use, it keeps saying „duplicate nickname”, can you help?
Здравствуйте. Я подтвердил свой почтовый адрес сменил пароль. Но второй раз войти не получаеться ни на устройстве на в преложении rose. Просьба проверить sergiy.apple@gmail.com
Hello @Khvelos1959
Please Email me the ID, password, and name you signed up for.
please, check the mail. Email sent from sergiy.apple@gmail.com
Hi! Please check my email sergiy.apple@gmail.com, I still can’t ente to rose apps centr
@Khvelos1959
I have sent you a verification email. After accepting the E-mail, you can use it after changing the password.
I received an email, I clicked on the link, but I still didn’t get access to rose app.
The second time I click the link it says
Account authentication failure.
why I can’t log in and use the device?
Hello @Khvelos1959
A temporary password has been sent to you by E-mail.
Thx! It’s work perfectly! I must change pas or I can still have temporarily password ?
