Hello @Khvelos1959
I’m sorry for taking a long time to solve the problem.
It doesn’t matter if you use a temporary password.
Hello @Khvelos1959
I have a few things for you to try.
Does it mean that your Rose device cannot connect with the RoseConnect app?
If so, please check if the IP address of the Rose device and the IP address of the device using the RoseConnect app are the same.
Does it mean that you cannot log in from Rose device and RoseConnectapp?
Are you signed up?
Rose device–>Settings–>User account.
If you get a login error even after signing up, please go to RoseConnect app–> Settings button at the bottom right–> My Page–> Find ID and password.
If that doesn’t work, please let me know the e-mail address you entered.
We will send a temporary password to the email address of the registered ID.
It is an initial set-up problem. I have never been able to login to RoseConnect. I have registered and everything seems to work normally. For example, a verification message is sent to my email. But when I try to login I get an error message.
I think I need a temporary password so I can start over again. I do not want to put my email address on a public forum like this. Can I send it to you in another way?
hello I received my rs 520 yesterday and I can’t create a rose connect account can you help me? here is my email ( allag.1305.aziz@gmail.com) thank you
Everything its ok thank you
We apologize for any inconvenience caused during use. If you tell us the part that does not work in the email below, we will respond kindly.
Before that, there are a few things to check.
Have you signed up for a Rose account?
Rose device–>Settings–>User Account–>Sign up
You have signed up, but can’t log in?
When registering as a member, you may enter the password only once, so you may have entered the wrong password when registering.
RoseConnect app–>Settings–>My page–>Find ID/Password
If the method above doesn’t work, please let me know the email address you used to sign up for Rose.
We will send you a temporary password.
Please send your email address to eunseong96@citech.kr when registering for a membership or problem.
Hello
I can’t register neither the rose 201 or the application
I enter my mail and a user name, but when I enter my password, each time it tells me that the entered value is incorrect
my mail contact@karl-l.com
cordialy
karl
I’m sorry. We recommend that you use a different email address as the email form is not supported by us. Currently, emails with special characters between @ and . are not supported when signing up.
Hi there having problems Rose login in i had the same id always same password its says no member found .Do i need to sign rose tube too and rose radio or Apple ?
Can you explain its says to duplicate nick name i did not receive verified email yet i even sign on another id [quote=“ROSELOA, post:2, topic:624, full:true”]
Hello, you need to verify your email after registering as a member.
Please log in to the email address you entered when registering as a member and verify.
[/quote]
Tried does not work [quote=“ROSELOA, post:2, topic:624, full:true”]
[/quote]
I need to check the status of your account.
Please message me the email address that you used for ROSE account.
It’s [loungedegnstudio@gmail.com
Question
Do I use same I’d and password on rose tube too or all other app ?
Maybe there’s typo in your email address?
Seems like this is your real email address…
You will have to make account again with loungedesignstudio@gmail.com
Or any other email address. The email address in your post is never registered.
Hi I’m still having problems with login I have tried signing with new email I don’t understand Nickname tried and set the password but no verification email received so what do you want me to do next
Please make your nickname shorter, like loungedesign and click ‘check for duplication’.
Thanks for your help all working now
Sinds de nieuwe update kan ik niet meer inloggen op mijn HiFi rose 150. Het ziet ook mijn e-mail niet meer. met herstelwachtwoord onbekende gebruiker.
Ook wat emails verstuurd niemand reageert. zoeken met de rose id ziet hij wel mijn emailadres.
Goedendag
Naar de nieuwe update deze week
Moet ik steeds opnieuw inloggen
Bij tidal en Qobuz
Please delete and reinstall the Rose Connect app.
Then try logging in to Qobuz on the app.
