ROON suddenly showing Parametric EQ in Signal Path
ROON is suddenly showing Parametric EQ in Signal Path. I turned on Roon’s Parametric EQ to see how it would affect signal path. With Roon’s EQ on, two Parametric EQs show up with Roon’s preceding the RS150.
Does anyone else see this?
I agree. It does seem to be happening with the Rose. Like you I have no DSP enabled anywhere. I’m sorry but I have no advice; I came here hoping Rose support would have a suggestion.
Yes, I see this too. Don’t want any equalization to the signal. Rose, please turn this off ASAP. Thank you.
Latest update seems to have corrected the issue. Thank you!! Nice job!! Appreciate you getting it corrected!!
fixed by latest update. thanks!
