My previous post from August 16 along with the link better explains why the audio cut out issues for many people relying on ESS DAC implementations. I have had the problem occur as early as 5 minutes of TV use with the inputs and as many as 3 or 4 times while watching a movie regardless of input between the RS150b and the TV. The audio cut out is intermittent and occurs for about 1 - 2 seconds before audio resumes for a while until the audio cut out occurs again. This is typical of the default ESS sabre settings that other companies making DACs have been able to mitigate by giving the user an option to relax such behavior so the chip doesn’t disconnect the audio in an attempt to fix jitter. This is why I provided a link to the datasheet and technical evidence of such a solution I think is referred to as “increasing DPLL bandwidth”.
If what I am trying to explain here isn’t making much sense then the research and explanation by JDS labs using the link from my first post above on August 16th I hope helps make it more clear.
I would post the JDS labs link again here if the forum restriction wasn’t preventing me from doing so. It says, “Sorry you cannot post a link to that host.”
